1997 4 Runner Starting Problempembroke 02-12-2006, 06:19 PM My 97 4 runner will not start. Just had the starter replaced with a reman starter and it was fine when I brought it home. Has been sitting in the driveway for a couple of weeks. Went to crank it up and nothing. Lights in dash come on. Antenna goes up and down. Battery is good (put the charger on it) No clicks coming from starter, no nothing. Could the reman starter be malfunctioning? What about the starter relay in the fuse box? How can I diagnose this problem? Could it be the ignition switch? Is there a cutoff switch in the gear shift or on steering column? Where should I start? Thank you for any light you can shed on this problem. Brian R. 02-15-2006, 07:00 PM It is most likely the starter solenoid (replace the contacts or buy a high-quality reman or new starter). Check the battery cable terminal connections at both ends for cleanliness and being tight. They don't have to be tight to power your accessories. Your starter draws alot of current and needs squeaky clean tight connections. http://www.automotiveforums.com/vbulletin/showpost.php?p=3560360&postcount=3 SidneyCanada 02-26-2006, 07:56 AM 19 Toyota (NipponDenso now called Denso) starter repair sites: http://www.off-road.com/4x4web/toyota/tech/starter/ - http://www.4crawler.com/4x4/CheapTricks/Starter.shtml http://char.tuiasi.ro/vw/reality/rogerb/4x4/CheapTricks/Starter.html http://yotarepair.com/startercontacts.html http://www.toyotaoffroad.net/afertig/88/starterrepair.htm http://www.4x4wire.com/toyota/maintenance/starter http://www.yotatech.com/~corey/tech/haveblue_starter/haveblue.htm http://www.sleeoffroad.com/technical/tz_starter_rebuild.htm http://www.startercontacts.com/install.htm http://www.startercontacts.com/images/OSGR_Exploded_view.jpg http://www.colorado4x4.net/tech/starter_contacts/starter_contacts.html http://www.barneymc.com/toy_root/techneek/starter.htm http://perso.wanadoo.fr/adherence.4x4/start_bj.htm http://www.automotiveforums.com/vbulletin/showthread.php?t=166530 http://www.toyotanation.com/forum/showthread.php?threadid=27312&forumid=10 http://www.toyotanation.com/showthread.php?threadid=27312&forumid=10 http://www.toyotaoffroad.com/Articles/Projects/starter/starter.htm http://www.tacomaterritory.com/boophoenix/starter.html http://www.tacomaterritory.com/boophoenix/starter/image01.jpg Starter contact kits (8mm ID hole): Ace Electric # S-5263 (only two contacts) Ace Electric # S-5264 (only two contacts) Metro # 66-82104 (only two contacts) (www.metroautoinc.com ,Pomona,California) Toyota # 28226-72010/80 (battery side)(also1KZTE-2LT-1KZT) Toyota # 28226-72080 (8808-9108) Toyota # 28226-16130 (9108-9308) Toyota # 28226-55050 (9308-9511) Toyota # 28226-70040 (9308-9511) Toyota # 28226-72040 (motor side if needed) Toyota # 28226-72010 (8808-9511) Toyota # 28226-74070 (9108-9511) (2000 Tundra & others) Toyota # 28226-22050 (2000 Tundra & others) Toyota # 28226-66060 (1993-1997 Land Cruiser 2.0 KW starters) For others besides 22R series: Toyota # 28226-54220 (motor side) (2LTE, 3L..LN13# IKZTE, 2L#, KZN130,LN108,112,85..4FC) Toyota # 28226-54250 (Diesel Surf 2.4TD, contains a new end cover and gasket) Toyota # 28226-54320 (battery side) (2LTE, 3L..LN13# IKZTE, 2L#, KZN130, LN108,112,85..4FC,3B-1HZ-BJ73-HZJ7#-1KZT-KZJ70) Toyota # 28226-17030 (battery side) (1H#-HDJ80-HZJ80) Toyota # 28226-56250 (battery side) (3B-1HZ-1PZ-PZJ7#) Starter contacts only (8mm ID hole): Ace Electric # S-5231 Ace Electric # S-5293 (crescent moon shape) Ace Electric # S-5295 (crescent moon shape) Metro # 66-82106 (www.metroautoinc.com ,Pomona,California) Tons more at: http://www.metroautoinc.com/PDF%20File/66-Denso%20Solenoid%20Contact.pdf Toyota # 28226-70040 Wilson’s Electric # 45-29-652 (maybe it’s 45-29-6521) Starter brushes: AC Delco # D762 GP Sorensen # 255048 Standard # JX-117 Whether your starter uses two rectangular types or one rectangular and one crescent you can substitute with two squares or one square and one crescent so any of the above part #'s for those kits will be the right ones,or about half of the auto electric shops in your local yellow pages would sell aftermarket contacts for only $5 each or the pair. If the brake and charge lights come on during revving of the engine then it's a sign that the carbon alternator brushes require replacing as this is the mileage for them to wear out. In alternators the brushes wear out on average every 140-170 000 miles where on the dashboard the brake & charge light both come on at the same time. About half of the auto electric shops in your local yellow pages sell carbon alternator brushes and copper solenoid starter contacts for about $5/pair.Another way to verify that the alternator is not charging is while the engine is running bring a metal screwdriver or any metal object near the alternator and if the alternator is working properly then it should act like a magnet and grab the screwdriver. For carbon brushes R&R: http://www.4x4wire.com/toyota/maintenance/alternator_brushes http://www.toyotaoffroad.net/afertig/88/alternatorbrushes.htm http://perso.wanadoo.fr/adherence.4x4/alternateur_kzj.htm http://www.automotiveforums.com/vbulletin/showthread.php?t=166525 http://www.toyotanation.com/forum/showthread.php?threadid=27270&forumid=10 http://www.pirate4x4.com/forum/showthread.php?s=&threadid=26734&highlight=alternator+brush+holder http://www.bitwalla.com/cruisers/articles/alternator.html http://www.barneymc.com/toy_root/techtalk/electric/altrnatr.htm For decoding the dashboard lights: http://www.powerbase-auto.co.uk/alternator_faults.htm http://members.1stconnect.com/anozira/SiteTops/energy/Alternator/alternator.htm Here are part #'s for Toyota alternator carbon brushes and copper solenoid starter contacts which are used in about 95% of all Toyota vehicles. Toyota alternator Brushes with holder: Toyota # 27370-35060=$29 CDN Honda # 31105-PZ1-003 Metro # 39-82003 (www.metroautoinc.com ,Pomona,California) Unknown brand name # F4019-53035 Alternator brush only (qty:1 brush unless otherwise stated): AC Delco # E724 AC Delco # E731 (side wire and concave tip) Ace Electric # DA-61 (brush only),S-5367 (brush holder) Beck Arnley # 178-1669 (side wire and concave tip) Beck Arnley # 178-1376 Borg Warner # X580 (side wire and concave tip) Canadian Tire # 19-2050-6=$4.49/pair Daihatsu # 27370-87302-000 Daihatsu # 27371-63020-000 Daihatsu # 27371-87501-000 Daihatsu # 27371-70300-000 Echlin # E601=$8.16 CDN/pair (UAP/NAPA) Echlin # ECHE601 Echlin # EC480 Echlin # ECHE480 GP Sorensen # 255047 (side wire and concave tip) GM # 94123056 GM # 96054118 Honda # 31144-PD1-004=$9.72 Honda # 31144-PD1-0040 Honda # 31144-PD1-0030 Honda # 31150-PR7-A01 Honda # 31150-PTO-003 Hino Industries # 021660-0390 Hino Industries # 021660-0510 Isuzu # 8-94123-056-0 Isuzu # 8-97032-308-0 Isuzu # 8-97032-310-0 Mazda # 021660-0390 Mazda # 021660-0510 Mazda # KL47-18-W75 Metro # 38-82001(side wire concave tip) (www.metroautoinc.com ,Pomona,California) Mileage Plus # E601SB Mitsubishi # MD604474 Mitsubishi # 21660-0510 Niehoff # WA571 (side wire and concave tip) NipponDenso # 021660-0390 NipponDenso # 021660-0510 Standard # JX-116 (side wire and concave tip) Subaru # 021660-0390 Subaru # 021660-0510 Suzuki # 31631-82610 Suzuki # 31656-82611 Suzuki # 021660-0510 Toyota # 27370-42010 Toyota # 27370-75060 Toyota # 27371-63020=$5.80 (up to 9105) (side wire and concave tip) Toyota # 27371-70300=$5.20 (9105-9511) Toyota # 27371-76004-71 UAP/NAPA # MPEE601SB Victory Lap # FAX57=$4.49 CDN/pair (Canadian Tire) Wilson's Electric # 26-29-7534 (side wire and concave tip)=$2.20 each CDN (Diesel Auto Electric)(Parts for Trucks,box of 10 for $3.40 CDN) Specifications: Length=15 mm Width=7 mm Thickness=5 mm Lead length=49 mm These Honda alternators are the same except the pulley must be swapped: 1986-89 Honda Accord (Carb),the EFI can be used but the voltage reg must be swapped 1990-93 Acura Integra For alternator upgrade: http://www.off-road.com/toyota/tech/100alt/index.html http://www.4x4wire.com/toyota/tech/alternator http://home.earthlink.net/~twopapa/bigalt.htm Sidney® ™ Repairs tv's,vcr's,home/car audio out of my home E-mail:sidneybek@yahoo.com Dartmouth,Nova Scotia Canada 1985 Toyota 4-Runner,solid front straight axle,factory cruise control,sunroof,22R-E,W56,RN60LV-MSEK,rusted rear step/towing chrome bumper with 247 000 KM http://groups.google.com/group/hfx.forsale/browse_thread/thread/43940ce83231ab85/4e4c696fbf04837f?q=sidney+tv+repair&rnum=1#4e4c696fbf04837f http://www.iwaynet.net/~nesda/May02/May18.html http://www.iwaynet.net/~nesda/SonyAudMod.html http://www.newark.com/product-details/image/mcm/image/32-9495.jpg http://www.tipsmaster.ca/hottips-1.HTM http://www.tipsmaster.ca/1011-TV32C50-007.jpg http://www.iwaynet.net/~nesda/June03/June0315.html http://www.iwaynet.net/~nesda/Apr03/Apr033.html O |\ __O _|_| \ (\__/) (='.'=) (")_(") ..> ...> ...> ...> .(....\............../....).. ..\....\........... /..../.. ...\....\.._.._../..../.... ....\..../....l..`\_./.... ..../....l....l....(..`\.... ...l.....l.._.l.._.\....\... ...l.....l__.l__.l''\....\.. ...\...................\../.. .....\__________/..... () () ^ () () / \ ^ ^ () () / \ \ ^ / \ | | / \ \ \____________ o o ) | | /_________\___\__\__________|_____| :grinyes: Brian R. 02-26-2006, 05:03 PM Sidney - I have previously copied all your links into the FAQ thread I referenced in my post. Thank you anyway. Carsick 07-16-2006, 05:05 PM I've had a similar problem with my 97 4 runner and assumed it was the starter contacts. I haven't gotten around to fixing the problem yet so I've kept on driving with my fingers crossed. Well, just today, I was backing up after a hour drive and the engine died. Do I still have a starter problem, or was it the alternator all along, or both? After the car died today, I'm thinking its the alternator. Thanks. KimMG 07-17-2006, 06:48 AM Your car died? Why? What are the symptoms? Please elaborate. Once your vehicle is started the starter has nothing more to do. Did you check for any codes before your car died. Did you check the battery cables? How old is your battery? Did you check your alternator belt? Were there any idiot lights on while you were driving. Carsick 07-17-2006, 09:43 AM Not sure why my car died. I put it in reverse and drove about 20 feet with 50 feet left to go, then, nothing. It's like I ran out of gas. But then it started back up and I continued to park. Isn't that a sign of an alternator going bad? My starting problems may just be related to a battery that's not getting charged? I didn't check any codes, the battery terminals should be cleaned though they don't appear bad, and the alternator belt seems tight. I didn't notice any idot lights while driving, but it was daylight and I was very tired. The battery was manufactured in Nov 03, but its one of those old exide battery's that Sams Club used to sell, until they had so many complaints they dropped that brand. Thanks for your reply. Brian R. 07-17-2006, 11:29 AM Don't clean your posts until you have checked the DTCs in your computer. Disconnecting the battery will delete them. Carsick 07-17-2006, 02:21 PM I checked the battery and alternator with a multimeter, both seemed ok (I'm no expert with the multimeter, 13v engine not running, 14v engine running). Then I had the codes checked, nothing there. Had a guy from autozone check the codes, then he tried to start it and we got the clicking noise. "Definitely the starter" he said. Engine dying is a seperate problem; fuel filter, low idle needs to be adjusted up?? Off to get the contacts and attempt to get the starter out. Doesn't look fun but I have step by step instructions with pictures, thx to the post above (www.4x4wire.com/.... ) Will post back reporting my results. Thanks for the help!! Automotive Network, Inc., Copyright ©2012
