need advice on a radiator replacement in a 96baldhead 02-11-2006, 11:02 PM tranny cooler fitting at top was leaking when i took it off to replace it the metal the fitting was screwed into had a flat o-ring around it which was mangled. 3 questions can i fix (ie:locate similar o-rings) or should i replace the whole radiator, and if yes how does the radiator come out(just an overview not a step by step drdisque 02-12-2006, 01:51 AM if its leaking from the O-ring, you should be able to fix it either with a new o-ring or simply a big clamp or sealant. The radiator is easiest to pull out from the bottom baldhead 02-12-2006, 06:48 AM bthanks man. ihave a day of tight space and fun ahead of me:banghead: Automotive Network, Inc., Copyright ©2012
