95 Jimmy injector conversion?YtseJam454 02-11-2006, 07:32 AM Has anyone heard of an injector conversion kit for 4.3L W from the standard injector assembly to the newer style injector? If so any info? Jimmy58 02-11-2006, 08:01 AM Has anyone heard of an injector conversion kit for 4.3L W from the standard injector assembly to the newer style injector? If so any info? Hi Jam, Can I ask why you would consider the change? In my opinion the newer system isn't any better than the older system Just different. You would have to maintain 6 injectors instead of 1. You would have to change the manifold sensors induction system and probably the ecm. Do you know of sugnificant advantages with the new system that I am unaware of? Just wondering. Jimmy 58:) rlith 02-11-2006, 08:52 AM A lot would have to be done for a conversion like that, you essentially would have to go to all 96+ parts, you would need the following 96+ ECM engine harness upper and lower intake tb setup csfi injector system (or the conversion kit to the newer style injectors) accessories (ac, alt, etc as well as the mounting brackets) updated BCM newer syle reluctor some other stuff Overall it's not worth it as you won't get any better performance out of it. The only advantage overall would be to swap the engine and everything else to the 96+ and add a turbo/sc, if you go that way in the end you will spend around 5-7k Automotive Network, Inc., Copyright ©2012
