Ooooh,
bummer Mr Bill,
4 years isn't really uncommon,
but 12k???? That's bizarre. Anyway, there's no question that the BMW M20 is an "Interference" engine, so there
will be damage. I was a Service Advisor at a franchise BMW dealer for 8 years "back in the day". I've seen plenty of belts break and never one without some measure of damage. Question is: How much damage? It all depends on the engine rpms and level of acceleration at the moment it broke.
The
ONLY way to determine is to disassemble, i.e. remove the Cylinder Head. The least amount of damage you can expect to have will be a few bent Intake Valves. I say Intake, as opposed to Exhaust, because the Intakes are a larger diameter, thus have less clearance than the Exhaust Valves from the pistons.
The next level will be
lots of bent valves, Intake and Exhaust, and maybe damage to the tops of the pistons.
Also, check the Head casting at the lower end of the Valve Guide, they can break from the force.
Worst case scenario is when the Head casting breaks at the Camshaft bridges and/or Rocker towers. If there's any Head casting damage at all, trash it. You may be able to find a good used one at a reputable dismantler or perhaps a reconditioned one. Or, there's always a used replacement motor ...
Problem is with old cars like ours is that it will often cost more to repair when big stuff like this happens than the car could ever be worth ... but then there's that
emotional attachment. Dr. Phil, where are you when we need you?!?
Good luck, keep us posted...
Paul (pada)
89 325iA
204k and still looks new!
