Help with axle hub nutakalima 02-10-2006, 07:50 PM Hey guys im taking my tranny out in my garage and the axle nut has stopped me in my tracks. I was using a breaker bar like tha manual said and it wasnt enough. I used a snip and snapped the head off the head of the breaker bar. Does anyone have any suggestions on where to go from here superbluecivicsi 02-10-2006, 10:38 PM break it off with the breaker bar and the tires on the ground. if that dont work, a 800 ft lbs impact gun will always do. the breaker method has always worked. GScivic7 02-10-2006, 11:55 PM yah, that's the way i've always done it too. That axle nut is a real bitch. c8r9x 02-14-2006, 04:35 AM 3/4" impact gun will get anything off those axle nuts are a pain i just pulled off my crankshaft pulley 1/2" didnt do shit 3/4" took it off in 1 sec ATMDC 03-17-2006, 01:33 AM i used a normal 1/2in ratchet with a 6 foot pole on the end lol, broke loose with very minimal effort corning_d3 03-17-2006, 01:51 AM Using an impact on an axle nut is a bad idea. They can cause CV joints and wheel bearings to fail prematurly due to brinnelling of the bearing surfaces caused by the impact. Always loosen and tighten by hand, vehicle on the ground, and torque them to proper specs. Automotive Network, Inc., Copyright ©2012
