coolant leakage
dontknowford
02-10-2006, 05:21 PM
coolant leaking from lower back of engine. can not see exact spot. can see stream of coolant lower middle of engine, no hose in area. please help.
irish30
02-10-2006, 09:16 PM
Need more info, is leaking close to the firewall at the tranny area or at the back of the engine close to the firwall?
dontknowford
02-11-2006, 01:03 AM
looks like right in the tranny area.
irish30
02-11-2006, 01:37 PM
Is the engine a 24v or 12v, 24valve has the water bypass tube at the tranny area, 12valve has the thermostat housing at that point, best way is follow the hose from the rad at the top and identify where they attach to the engine.
dontknowford
02-14-2006, 03:52 PM
ok the leak is a freeze plug, the problem is. is there a way to replace without removeing the manifold and the transmission?
Colt Hero
02-14-2006, 05:58 PM
Never actually saw it, but my Dad's '97 Taurus GL had a freeze plug blow inside the tranny area. The tranny had to be removed to get at it. $700 to replace a $5 plug! He dumped the car immediately afterward. That was the last straw...
mechhound
02-14-2006, 10:06 PM
I am not familiar with just where your bad freeze plug is located. They make a rubber freeze plug that you insert and tighten a bolt to install. These work great where there is no room to pound in a replacement standard freeze plug. Of course you still have to have room to be able to remove the old freeze plug and be able to install the much simpler rubber freeze plug. So this may or may not work for you. Hope this works.
dontknowford
02-16-2006, 10:38 PM
very nice, the rubber expansion plug went in perfectly. did not have to remove transimission. $ 3.49 part nad no labor. saved me $800. Thank you
dontknowford
02-16-2006, 10:45 PM
sucks to spend that much money on a car that isn't worht that. every time you crack the hood on that Taurus it can be 500-1000. its got to go.
