drivers door speaker
springhead321
02-09-2006, 07:19 PM
Hey People, I have a 2000 z71 with drivers door speaker or speakers blown out, i want to replace myself.
Do we have to take the panel off or can i pry out the oblong speaker grill,
I dont want to mess up my truck, not sure how to take panel off or if i need too.
Thank Later
jethro_3
02-09-2006, 09:16 PM
Pop the control panel up(panel with window and lock controls), Remove the wire connectors from the control panel. Take the screw out in the upper left corner of the opening. Take the cover off around the handle and remove the long screw. Then lift the panel straight up and you will be able to get to the speaker.
Simple...
gremlin96
02-09-2006, 10:05 PM
take a look at the inside of your door for water damage. my speakers are taking a dump. its becouse water is getting inside the door. i have had it back to the stealers a few times so far thay cant find ware the water is getting inside the door. I have told them to use water on the door lol. up to a week after it rains the seals are still wet. heck the door lock and handles have frozen up to 5 days after a rain. all its got to do is rain for a hour and get cold befor it has time to evaprate. its a bear useing a hair dryer on the door just so i can open it every time the temp drops.
springhead321
02-09-2006, 10:11 PM
Excellent, thank you very much guys.
ill do this in the morning.
masapell
02-10-2006, 05:18 PM
Yeah, I had to do the same thing. Its pretty easy to do, but if you can, buy some aftermarkets.
springhead321
02-11-2006, 12:13 PM
Absolutely, didnt do it yet, to cold outside, but if its an easy enough panel to get off, ill change both door speakers with something good,
Thank
HD2500
02-13-2006, 08:36 AM
I'm having problems with my drivers side speaker and the power mirrors. I took the door panel off and the speaker started working hmm... I'm thinking wiring or connector. I followed the wiring through the door with my hand and noticed that although there is a boot where the wires come in, there was no rubber grommet protecting the wire harness as it enters a hole inside the door. And I believe there may be some rubbing going on. I took the mirror controller apart and lost two more directions. I put everything back together and things are exactly the way they were before I opened the panel. I will dig deeper when I have more time and I have the service manual I ordered.
