95 Caravan Problems, Clunking in front endRottweiler482 02-09-2006, 05:14 PM Hello I'm trying to help out a friend who just purchased a 95 Caravan, and when it rolls or anything there is a really bad clunk in the front left corner. It seems to be binding up or something, it does it when you put it in gear, or when it's in nuetral. Can't figure out what it is, seems like a bad bearing or axle but not sure. Thanks for the help. Jerry xtreme barton 02-09-2006, 05:44 PM could be your bearing/hub assembly... check out your cv shaft to .. check to see if the boots are damaged for an initial inspection.. does it get louder when you turn the corner ? or reverse ? Rottweiler482 02-10-2006, 02:51 PM not it doesn't get louder or anything when you turn, it pretty much stay's the same, clunking and binding.. xtreme barton 02-10-2006, 08:10 PM all i can suggest really is to start a tare down and inspection. Automotive Network, Inc., Copyright ©2012
