Engine lubricationMugen_R 06-22-2002, 11:21 PM hi, I bought this stuff from canadian tire which is called: Restore and Engine Lubricant. and it's a silverish type can, and it says on the can, 8 cylinder Formula. on the back, it says to pour the whole can into the engine oil and put in when changing oil. because it says 8 cylinder formula, will that work on my 4 cylinder 1990 Acura Integra??? Steel 06-23-2002, 12:43 AM sure, just put half of the recommended amount in, and you're all set. Although most of that crap they sell is all B.S. anyway, but <shrug> 454Casull 06-23-2002, 09:52 AM Yup. It's all garbage. Mugen_R 06-23-2002, 10:09 AM I just need some stuff that will "help" my engine out and it's 419 000km's on it. I thought when it said 8 cylinder formula that it would be like helping 8 objects out in the engine. 454Casull 06-23-2002, 01:57 PM Errr... Cylinders aren't quite objects. Rather, the lack thereof. I can see now why you bought that. :) There's nothing you can do to help your engine by way of additives, unless you count using heavier-weight oil if yours is leaking/burning oil. Mugen_R 06-23-2002, 03:30 PM Originally posted by 454Casull Errr... Cylinders aren't quite objects. Rather, the lack thereof. I can see now why you bought that. :) There's nothing you can do to help your engine by way of additives, unless you count using heavier-weight oil if yours is leaking/burning oil. it's burning oil like normal but I wanted a product that would sorrta clean up the insides of the block and internal parts of the engine. any recomandations on good fluids that i can use to clean the insides of my engine or help it by pouring some better lubricant in there??? 454Casull 06-23-2002, 03:35 PM If you already didn't get the message - there are no additives on the market that will clean out an engine. Why not just send it to a shop to have everything cleaned? 454Casull 06-23-2002, 03:36 PM In response to that last question - you can put synthetic in it. Automotive Network, Inc., Copyright ©2012
