Idle Issues w/ 94' 740 IL
minrodthomas
02-08-2006, 08:46 PM
Greetings,
There are times when I put the car in Drivethat it idles way down and it cuts off. The idle also goes up and down while sitting still. Any experience with this?
Tuffdrvr88
03-09-2006, 01:53 AM
Take brake cleaner and shoot it around the intake manifold, you may have a vacuum leak.
minrodthomas
03-12-2006, 11:22 PM
Thanks for the info. I let a mechanic look at it. He checked all the vacuum lines. He determined it was the idle control motor going bad. Hopeflly, that's all it is.
Tuffdrvr88
03-21-2006, 01:57 AM
most likely thats all but it wont be cheap lol
jsbmw
04-12-2006, 05:45 PM
Greetings,
Hi
Another thing to check is the crankcase ventilation valve, if the diaphragm is damaged or worn, the valve will not regulate th eengine pressure correctly causing a rough or erratic idle, and sometimes some smoling during driving. This can be reaplaced cheaply and easily by a relative amateur, as opposed to paying BMW to take the engine out, or remove the inlet manifold in order to do the swap!
We are small BMW E32 / E34 specialist breaker, supplying information and parts worldwide. We carry a dozen vehicles or so at a time, split between 5 and 7 series. If you would like any further help or information please feel free to visit our website at www.jsbmwspares.co.uk to obtain our contact details.
Regards
jsbmw
