Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Kia > Sportage
Old 02-07-2006, 08:47 PM   #1
cojimar54
cojimar54 Normal reputation
98 Kia Sportage EX leaking by oil filter area
Do somebody know how to replace the o-rings that are located between the oil filter base and the oil cooler in a 98 kia sportage EX???
cojimar54 is offline   Reply With Quote
Old 02-08-2006, 11:59 AM   #2
MeettheCreeper
MeettheCreeper's Avatar
MeettheCreeper Normal reputation
Re: 98 Kia Sportage EX leaking by oil filter area
I have changed several. This is not something I would recommend to the do it yourselfer though. You will be doing alot of this .
There are 3 14mm head bolts that hold the adapter in place. They were put on with a 1 inch impact and five guys with a 40 foot breaker bar. They are tight.
They can be removed it just is going to take more patience than most folks have.
MeettheCreeper is offline   Reply With Quote
Old 02-08-2006, 06:42 PM   #3
cojimar54
Thank you for your answer.
I saw the 3 bolts and the problem is how to access one of them that is just below the motor mount. I think the only one way is removing this motor mount for better access to this bolt.
What do you think??
Old 02-09-2006, 09:12 AM   #4
MeettheCreeper
What do you think??
Never removed the motor mount to remove this. Have always used a swivel and a socket. Like I said it isnt an easy job.
Old 02-09-2006, 08:42 PM   #5
cojimar54
Could you explain me in details??
From where?? Up or down of vehicle?? I don't think you have enough space to introduce a socket in at least one of the nuts
Thank you!!
Old 02-27-2006, 07:43 PM   #6
cojimar54
Thank you!!
One last question, because I'm decided to do the work next weekend.
Do you remember the size of the socket I have to use to remove the bolts?
Thank you
Old 03-01-2006, 01:24 PM   #7
MeettheCreeper
Thank you
The bolt heads are all 14mm. It would be difficult to explain the removal procedure in this forum. I can tell you it is not going to be easy. You have to have alot of patience.
Bookmarks
Google
Web AF
