Brake Light Complications, Need help immediatleyHyghtz215 02-07-2006, 05:43 PM Heres the story. I recently bought a 1995 Accord and for my first modifications I installed a pair of L.E.D Tail lights from TASAUTO.com . Installation was a cakewalk. When I got done I tested the lights, everything worked instead of the damn brake lights. They worked before the aftermarket lights were installed so I figured I must have missed somethin during the install. Everything was hooked up right so the next day I called up TASAUTO and talked to a techie. He said that it was and odd problem and to check the fuses out, and to try a 25-30 amp fuses also since these lights are more powerful than the stocks. So I go to my job " bestbuy " and got my friend at the install bay to check the fuses. He checked the fuse and it was perfectly fine. So he put the same fuse back in and we tested the lights. They Worked! my problems were now over... Wrong! The next day i get in my car, I noticed that the red light from the center brake light was not reflecting of my back window. Back to the drawling board. So I go to back to the job and put a 25 amp fuse in place of the original. I hit the brake and ....Nothing. TAS's guy was wrong. So I pulled the 25 amp fuse out and place the 20 amp back in thinking that would do something. I hit the brake and the lights lit!! so I took my foot off and applied the brake again. Nothing! Im so puzzled right now. So I go to look at the fuses under the steering wheel thinking there could be somethin blown under there, But the guy who had the car before me lost the fuse diagram box. I dont know what the hell Im even looking at now!!! So now Im stuck, I fear driving my car because the cops hassle me enough for my barely legal tint, so if they find out my brake lights dont work, they have a reason to give me a nice little ticket. So I need help big time. Im not trying to pay big time bucks for a electrician just to run a diagnostic. So please If someone could give me some advice it would be much appreciated. Also if someone could give me a site where they would have a 1995 accord fuse box diagram incase anything happens in the future would also be great too. Thanks in Advance. AccordCodger 02-07-2006, 06:51 PM Let's see. You've got illegal tint, marginally-working rear lights, and you want help "immediately" but you don't want to pay for it. Hmm. Electrical problems don't usually have a simple answer, which you'd find if you did a search here. It's a matter if painstaking trouble-shooting, looking for shorts (if fuses blow) and bad connections (if they don't). At least spring for a manual, so you have a wiring diagram. And why not go to a junkyard and get a fuse box cover? mpumas 02-08-2006, 10:11 PM You think you have problems now, put in a bigger fuse then the orginal and have something short out. You may be able to kiss your car good bye. Honda does not use any larger wire then absoutely required. So if you put in larger lights/LEDs and a bigger fuse, you risk melting the insulation off the wires or melting a wire. Obviously you need a meter to find out what is happening. But one thing is sure, all power for the brake lights is going through the brake light switch. I would look there. Maybe you can short the wht/yel and grn/wht wires together to bypass the switch. dreager 06-22-2006, 10:17 PM Get the free service manual in "sticky" section for diagrams jeffcoslacker 06-22-2006, 10:54 PM Ok, here's the deal, most likely. For some reason, your current setup isn't supplying enough ground capacity to light the brake lights. That warning light on the dash detects a low continuity condition in the circuit (usually when a bulb burns out), but poor or incomplete grounding will do the same thing. What you need to do is determine how the brake light sockets derive their ground to the chassis, and fix that, or rig something up to provide a strong alternate ground path (like a second ground wire strung directly to and unpainted part of the body. That should cure the problem, I'm almost sure of it. AccordCodger 06-23-2006, 06:46 PM 4-month old thread, JeffCo. jeffcoslacker 06-23-2006, 07:40 PM 4-month old thread, JeffCo. Oops. I didn't dredge it up...didn't look at the dates, though.:lol: AccordCodger 06-23-2006, 08:41 PM You're forgiven. It only got my attention because I saw that I had posted a snippy response to it a (relatively) long time ago. But you're right - you weren't the one that woke it up. :) Automotive Network, Inc., Copyright ©2012
