Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Peugeot > 106
Old 02-07-2006, 05:11 PM   #1
luk0zade
luk0zade Normal reputation
2001 106 1.1 independance, engine problems any help?
hi
Ive got a peugeot 106 1.1 and have a few problems but dont know what is causing them can anyone help?
The first is that when idle the car flickes between 900 and 1000 revs causing a slight judering sensastion. is there anything that can be done to eliminate this? Secondly, under my oil filler cap there is a slight build up of like a white foam. Thirdly, the engine has what looks like a rubber seal arround the bottom of the rocker cover and has split at the corner.
Can any of the above be any major problems or are they a sign of worse things to come?
The car has only done 23,000 miles so im hoping it is nothing major.
any help will be apreciated
regards luke
luk0zade is offline   Reply With Quote
Old 04-05-2006, 09:47 AM   #2
4shworth
4shworth Normal reputation
Re: 2001 106 1.1 independance, engine problems any help?
Hiya mate, in relation to your problems. Does the engine judder constantly or when it is just cold? I have a pug 106 zest 1.1 2000 and mine is the same when cold but within 5 - 10 minutes its fine. The white foam under your oil filler cap seems to me to be water in the oil... maybe caused by condensation due to the winter. Thirdly, your seal should be fine at the bottom of the rocker cover but to be on the safe side change it, it is only a half an hour job but that may well be the cause of the water getting in the engine. Let me know how you get on.
4shworth is offline   Reply With Quote
Bookmarks
Google
Web AF
