Rear coils
bigpest88
02-03-2006, 12:38 AM
I have a 95 4Runner that is stock when it comes to the suspension, and was wondering what size coils i can put in the back to lift it in combonation with a ball joint spacer, diff drop and cranking up the torsion bars? :dunno: I plan on running 32's with 10 inch rims or maybe even 33's with 10 inch rims. right now i an running 31's on 10 inch rims, and have little rubbing.
Thanks,
ChRiZ
xtreme barton
02-03-2006, 02:11 AM
10" rims ??? lol
bigpest88
02-03-2006, 11:10 AM
10" rims ??? lol
I meant 10 inch wide rims:nutkick:
Willybeamish
02-06-2006, 07:34 PM
O.k for the rear you can get some Old Man Emu 901HD coils and they will give you aboot 3inches of lift in the rear, if you go this route you might wanna consider the panhard drop cause if not the driveline may rub on the gas tank durring articulation of the rear axle. For the front the BallJoint spacers works good, if you get a 1" to 1.5" spacer you can fit some 33s on some 10" wide rims. The only down side to doing a spacer lift in the front is that you are putting the front cv joints at some different angles making them more prone to snap.
bigpest88
02-06-2006, 10:35 PM
Thanks for the info, Will a diff. spacer help with the problem of the CV shafts, and what shocks can i use or should use that just bolt to the stock location???
