1985 735i fuel pump/relay problem?
Mike Mills
02-02-2006, 11:14 PM
I removed my gas tank to replace all the hoses as they were rotten.
Found out later I could have replaced them without removing the tank.
I turned the tank upside down to drain all the gas before re-installing it.
Now the in-tank and outside tank fuel pumps do not function.
I think it may be the fuel pump relay, but I can't locate it as I don't know what it looks like (the book says it's on the cowl)? I only measure .5 volts at the connector to the in-tank pump. Same .5 volts at the fuse which is good.
HELP would be appreciated very much. Mike
xtreme barton
02-03-2006, 01:30 AM
Relay is located : UNDER HOOD, DRIVER SIDE, FRONT SIDE OF STRUT TOWER,
MOUNTED ON FENDERWELL
xtreme barton
02-03-2006, 01:32 AM
50 - 70 dollar cost for new relay ..
Mike Mills
02-03-2006, 12:53 PM
Thank you I will look there for it I appreciate your help, any clue on how to verify it is okay?
xtreme barton
02-03-2006, 02:30 PM
i dont off the top of my head.. do youhave a repair manual ?
otherwise you can kinda cheat the system ...
go to autozone and purchase one and then test it and if it makes a difference than keep it otherwise return it .. make sure its autozone though because they 99% of the time have hassle free returns .. just dont scuff it all up and make visible damage ...
