replacing the back 4 plugs....fordpsdman 02-02-2006, 03:01 PM I serached around the forum for any info on replacing the back four plugs to no avail.... I have a 98 with a surging problem. I put a new fuel filter on, checked the FPR, and had the tranny flushed and filter changed (thinking it may have been a torque converter lock-up) and the problem remains. So now I'm ready to go after plugs (and possibly wires). A casual glance at the rear 4 plugs makes me cringe :eek: ...does anyone have any tips or tricks to get to these plugs ? Thanks in advance, Brandon newscarver 02-02-2006, 05:14 PM there should be lots of memos about this...you have to unbolt the 4 small bolts that hold down the coil pack,move this around to get to all the plugs ...3/8 drive ratchett,2 inch extension and a ujoint can get this done in about 20 minutes androsvalentino 02-09-2006, 03:44 AM check coil packs. if high miles replace them while you're in there. napa has them. denso iridium plugs. vitek performance wires. best advice is to buy a service manual. i am gettin one . nvmyvettes 02-11-2006, 03:52 PM I dont think surgeing would be a plug and wire problem. May be though.Sounds more like a fuel related problem.Have you tried the throttle body/EGR clean? Or maybe your TPS? Does your SES light ever come on? Hesam 04-10-2006, 08:11 PM To change rear plugs, open the 2 nuts behind the 4-coil-pack with a 6-inch extension then take the coil-pack off. The SOB engineers put them under coil packs so you can't reach them and have to take it to their robber Dealers and pay $700. By the Way, use NGK Irridium plugs and Borg-Warner wires. The surging is not from plugs it's from Fuel and valves/sensors. Bad plugs/coils only make hesitation/misfire and low power. I serached around the forum for any info on replacing the back four plugs to no avail.... I have a 98 with a surging problem. I put a new fuel filter on, checked the FPR, and had the tranny flushed and filter changed (thinking it may have been a torque converter lock-up) and the problem remains. So now I'm ready to go after plugs (and possibly wires). A casual glance at the rear 4 plugs makes me cringe :eek: ...does anyone have any tips or tricks to get to these plugs ? Thanks in advance, Brandon back2life 04-21-2006, 11:18 PM try to put ac delco parts back on if all possible. and check the fuel pressure after it has been driven for a while to get it hot(fuel pump ) Automotive Network, Inc., Copyright ©2012
