Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > BMW > 3 Series
Old 02-01-2006, 01:36 AM   #1
tocksme
tocksme Normal reputation
Unhappy Complete electrical failure?
Hello. I have a 1997 BMW 328is. This morning, after starting and running just fine two days ago, the car had no electric power whatsoever. Unlike a weak battery situation, I could not even unlock the doors remotely with the key fob. After entering, there was no response from the starter or anything else electric.
Here is the strangest part. When I attempted to jump the car, I got small showers of sparks and cooking cables. Please believe I know how to properly jump a car, but nevertheless double and triple checked the cable connection procedure with manual in hand. Same result.
The only thing extraordinary about my car's condition is that one month ago an anonymous driver ran into it, denting but not crushing the front passenger side fender at the door seam. It has been running fine, though.
What could cause a complete electrical system failure? Could the odd battery sparking and hot cables be related? Wiring behind the fender damage?
Many thanks for your thoughts. -MT
tocksme is offline   Reply With Quote
Old 02-01-2006, 08:30 AM   #2
Domingues
Domingues's Avatar
Domingues Normal reputation
Re: Complete electrical failure?
if the car is manual take it to a hill, get some on to push it down while ur inside, as the car begins to roll try and start it, hopefully that works. Worked on my cousins ford capri, or then just get some1 to push it and while ur inside try and start the thing, im not sure what could be wrong :S maybe ur battery has been polished off
Bmw E30 1986 325e
170LBS-FT of torque
121Hp
Domingues is offline   Reply With Quote
Old 02-01-2006, 08:31 AM   #3
Domingues
Domingues's Avatar
soz but i forgot to mention have it in first gear
Bmw E30 1986 325e
170LBS-FT of torque
121Hp
Old 02-17-2006, 12:04 PM   #4
Mendari
Mendari Normal reputation
I think the electrical system isn't properly grounded. Without the complete circuit, you will get sparks, heat, smoke, etc. when you apply an electrical current.
Mendari is offline   Reply With Quote
Bookmarks
Google
Web AF
