Plug Wires?
NYSteve
01-31-2006, 09:42 PM
Just aquired a '95 Aurora that runs rough. I figured something electrical. Maintenance records show that the plugs were replaced 6 months ago, as were the coils. When I unplug the spark plug wires on cylinders 1 and 4 while the engine is running, nothing happens. If any other wires are unplugged, the engine slows down and runs worse. If the wires are switched (cylinders are fired in pairs, so you can switch them with the paired cylinder), the new cylinder with the old wire does not have spark. I’m 99% sure it’s the wires, but I just wanted to verify before I spent $120 on new wires. Anyone have a similar problem, or a suggestion?
zimaad
01-31-2006, 11:02 PM
These cars are fairly picky when it comes to plugs and wires. What kinds was put on the car 6 mos ago? I think you'll find that most people recommend putting on the AC Delco OEM plug wires and plugs. Yeah...they are a bit expensive at $100+ for the wires and $6/plug, but they just seem to work better. Also, wires 1 and 4 come from the same coil pack. Maybe you have a bad coil pack. That's a cheap fix...maybe $30 for a coil pack I'd guess. Other things that tends to lead to rough running car is fuel pressure regulator(FPR), fuel pump, intake leak(common...will hear a whistling esp when cold and rough/hesitation when under slight acceleration). The mass air flow sensor can lead to a bunch of idle/fuel mix problems too...thats a whole other bag of worms though. I'd rule out the simple fuel/electrical things first. Also...you getting any codes?
best of luck
androsvalentino
02-01-2006, 04:23 AM
i currently have borg warner select ch7855 wires. denso iridium IT-16 (5325). check out vitek wires. vitekperformance.com good design. look sharp. i had ngk iridium, denso is better design, smoother, better economy, more power. i'm gona switch to vitek next.
NYSteve
02-01-2006, 10:40 AM
best of luck
1 & 4 come from the same coil? I traced all the wires back to each coil and 1 & 4 dont come from the same one. I assume that could be the problem, however, theres still no spark on the other end of the wire no matter where its plugged in. And no, no codes. The check engine light isn't even on. Coils are around $30, yes. Everything else you list I dont believe has to do anything with the car running poorly. Theres no spark to 2 cylinders, and the plugs w/o spark are wet (with gas). And it runs, so the fuel pump isnt bad.
androsvalentino
02-01-2006, 04:12 PM
fpr fuel pressure regulator. possible. vacuum leak. clean egr valve, throttle body, new fuel filter.
androsvalentino
02-01-2006, 04:13 PM
idle sensor.
androsvalentino
02-01-2006, 04:16 PM
i just changed fuel pressure regulator. new fuel filter, cleaned throttle body, new goodyear gator belts. smooth, picked up mileage, power. sounds like bad wires if the coils were changed recently. vitek wires. go with the good plugs. denso iridium.
blindman858
02-01-2006, 06:59 PM
I had a number of OBDII sensor code errors relating to fuel system,0701 and 0703. Replacing fuel ralated components had no effect. Took it into dealer and he said car had bad plug wires and two plugs with carbon traces. Dealer replaced plug wires and cleaned carbon off plugs and it now runs like a champ
Smoothe LJ
02-01-2006, 07:05 PM
http://www.volvospeed.com/Reviews/iridium.htm check out this site it might change ur mind!
androsvalentino
02-01-2006, 10:25 PM
i will post if i have any probs. anything can happen when changin plugs. not putting anti seize lube, over tightening, bad threads, doesn't mean this plugs suk just cause of some guy with a volvo.
NYSteve
02-02-2006, 02:31 PM
Just bought a new coil, and put it in. Now i have another problem. The wire from the coil to cylinder 1 sparks all over the place from the terminal. what could be causing this?
androsvalentino
02-02-2006, 02:36 PM
change the wires.
NYSteve
02-02-2006, 02:47 PM
Change the wires eh? Ugh, thats what i was afraid of. $140 aint cheap but i guess i dont have too many options.
androsvalentino
02-03-2006, 02:01 PM
get the viteks. vitekperformance.com if u put the cheeps you'll wana change them in bout 2 months after you begin to appreciate the car more. not everyone wants to do this car up, i know. some wana keep the blend in sleeper, mini van look.
NYSteve
02-03-2006, 06:25 PM
Well, i think ive ruled out the wires. switching wires completely with another cylinder still gives very little spark at the other end, even with a new coil installed. and the wire that i thought was bad, gives great spark when put on another terminal. Now im thinking that either the ignition module is bad, or the ECU is junk. both big $$$$. i cant really think of anythig else that could be making one coil give weak spark, and the other three fine spark. i'd like to not have to spend $500 and find out there still something wrong.
also, where is the connector to plug the car in to get codes? maybe that'll narrow it down for me
kiway22
02-04-2006, 02:54 AM
You can take the whole coil set up to Advance auto( don't know about autozone)and they should be able to check it for you. That should eliminate the coils as the problem. If you suspect 2 plug wires, you could go to a salvage parts yard, and grab a couple to see if you get fire. Are the connectors on the platform, that the coils set on secure? If you can't fix the problem, no sense in wasting too much money. You may have to take it to a dealer. I have heard from guys here that cadillac dealers do a better job on the Aurora. And if you do, be sure and get an estimate from them, to do any work on the car. By the way, how many miles on your Rora?
NYSteve
02-04-2006, 10:32 AM
theres 114k on the car. ive pretty much ruled out the coils and the plug wires as the problem. (very few junk yards have auroras anyway) The connectors on platform that the coils sit on are all fine. And i'm reluctant to take it to a dealer for them to tell me its going to cost $100 to tell me whats wrong. then having to spend $350 for the part.
Sweet William
02-04-2006, 10:58 AM
There's a lot of experience on here with plugs and wires. The best way to go is AC/Delco. If you don't think so then maybe you should buy some of those Bosch plugs with 4 electrodes. Four electrodes must mean four sparks and I'm sure the cage around the base won't interfere with flame propagation. (Sarcasm intended)
androsvalentino
02-04-2006, 03:02 PM
the bosch with the 4 . not good idea. tried them on chevrolet monte carlo. those have a tendency to burn off some of the electrodes. if you're gona try to nickel dime this car, get out now, get a honda civic or mini van. or else you're gona wana take a sledge hammer to it in a cuple months when something much spendier comes up!
ghutchin
02-04-2006, 06:01 PM
bosch +4's are as expensive as the AC delco platinums. Plus 4's can work better because the spark is distributed at four points around the electrode. At an given time only one the four fires, but its a more symetrical system which means over time as part of the plug wears other areas will be used giving more even wear of the electrode.
Sweet William
02-05-2006, 01:59 PM
There is no way that having that mess in a combustion chamber can be good. There is more going on in a cylinder then just the plug making a spark. What's happeing with the other three electrodes while one is firing (besides disrupting the flow of everything)? Collecting carbon deposits so they can't fire and block flow even more? Just another gimmick to get your money. Can you say Splitfire? These things had all kinds of silly claims behind them when they came out. The really funny thing is to listen to guys brag about how much more power they have because they put new super duper splitfire spark plugs in. Maybe it does run better because your old plugs had 100,000 miles on them. Maybe they should look at what is really going on with the engine as a whole system. One good plug is not going to make more power than another.
I have run iridium in 500cc two stroke engines with good results. They have actual science behind them.
Smoothe LJ
02-08-2006, 08:40 AM
If antone is considering bosch 4 spark plug DON'T DO IT PLEASE! Those stupid plugs messed up my car big time. The thing is that tha hole the actual spark comes out is so small that it clogs very easy. i used some it not only did all tha spark plug get ruin but i also had to get new coils and it burned up the wire. Jus dont make tha same mistake i did. SAY NO TO BOSCH!!!!
baron1701
02-08-2006, 12:28 PM
Whoaaa Here..
I Put The Bosch's In About 6 Months Ago, Nice Performance Burst And Better Economy. I Haven't Run Into Any Probs Yet. I Am Looking Into Replacing Them Soon, Ill Think Twice.
androsvalentino
02-09-2006, 02:55 AM
denso iridium! the bosch 4 will end up breaking, burn off one of 4 electrodes. happened to me with chev monte carlo. ngk is ok too. denso is better made.
