changed thermostat but still overheating
hocuz
06-19-2002, 07:23 PM
i just changed out the thermostat but as i was driving to work this morning, the car started overheating again. it seems worse now because when i turned on the heater before, it would cool the engine down but that didnt help. do you suppose that the water pump is bad?
please, help me.
thanks
boingo82
06-19-2002, 10:31 PM
To my understanding, when a water pump goes, it leaks coolant everywhere, and tons of it too. You'd notice that.
T4 Primera
06-20-2002, 03:31 AM
First I'd check the system is bled properly. The SR20 is very sensitive to air in the cooling system. Find a good procedure from a FSM or on se-r.net and follow it.
If the correct mix of corrosion inhibitor has been consistently used in the coolant then the waterpump should be alright.
