Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 01-30-2006, 12:00 AM   #1
MrDS0613
MrDS0613 Normal reputation
Replace Air Box
I'm looking to replace the air box on my '98 lumina 3.1L with a cone filter. Can this be done and if so, what is a good brand of filter to use?
MrDS0613 is offline   Reply With Quote
Old 01-30-2006, 01:05 AM   #2
Schurkey
Schurkey Normal reputation
Re: Replace Air Box
TOTAL WASTE of time, money, effort, and enthusiasm.
Declared "the flat out DUMBEST poster on this board" and have earned the moderator-sanctioned rating of "dumbass". And mighty proud of it.
Schurkey is offline   Reply With Quote
Old 01-30-2006, 07:11 AM   #3
Jonn
Jonn Normal reputation
Re: Replace Air Box
Not to mention, loud sucking noise in engine bay when accelerating hard. I tried it, went back to original and a good filter, then then again i dont like loud exaust either, ummmm.... unless its a V8
Jonn is offline   Reply With Quote
Old 02-01-2006, 12:12 PM   #4
Carwhiz
Carwhiz Normal reputation
Re: Replace Air Box
now here's a topic that can lead into discussion...haha...so many people think that the cone filters are extremely necessary, I sell a dozen filters a week on average. The idea behind cone filters is superb, however, there are only certain applications that these filters work properly. In order for a cone filter to work proplerly you still need cold air comming from outside the engine area. On the 3.1L's there is not sufficient room for your cone to get any air except for hot exhaust heat, which actually harms engine performance. I always TRY to talk customers into buying K@N panel filters, because your car allready contains a cold air intake. The cone filters are ideal for trucks, or vehicles with open engine areas to allow cold air into the filter. You know my advice, PLEASE GIVE ME SOME FEEDBACK ON THIS! I'd appreciate it!
Carwhiz is offline   Reply With Quote
Old 02-01-2006, 07:53 PM   #5
1993LUMINATOR
1993LUMINATOR Normal reputation
Send a message via MSN to 1993LUMINATOR
Re: Replace Air Box
l totaly agree with you, it allready is designed to suck cold air from behind the drive headlight, what l did on my engine was removed the air restricter, sure its a tad louder but hey it actuly gave me a better up off the line BUT sucks shit in the higher RPM from around 5500-9200 when it could use the turbo or SC And l gota turbo so its different
1993LUMINATOR is offline   Reply With Quote
Old 02-09-2006, 07:26 PM   #6
MrDS0613
Re: Replace Air Box
Ok, thanks for the advice. Hey 1993LUMINATOR, what is the "air restrictor that u removed, and how do u remove it?
Old 02-09-2006, 07:42 PM   #7
1993LUMINATOR
Re: Replace Air Box
you remove your airbox
see the nose at the bottem facing the front of the car.
that rivited on just take a flat head screw drive and prie at it then it should pop or break off
l'v found it restricts the air and adds a bit of potential to this engine
caue if any owner knows these motors will pump out 205hp with very little modification if you fallowed up on the history of this motor the 2nd generation 60degree V6 redesigned for 1993
Brad
Bookmarks
Google
Web AF
