Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 01-29-2006, 09:26 AM   #1
itzed
itzed's Avatar
itzed Normal reputation
Parking brake light won't go out
I recently replaced most of the components to the cooling system: Radiator; cap; both hoses; thermostat; water pump. In the process, when removing the air intake components, I must have disturbed the parking brake cable, and now I can't get the light to go out. It seems to be functioning fine, engaging and releasing, but the light just won't go out. Any ideas?
Ed
itzed is offline   Reply With Quote
Old 01-29-2006, 09:45 AM   #2
SLoe
SLoe's Avatar
SLoe Normal reputation
Re: Parking brake light won't go out
Those kind of lights are always sensor/switch activated. Find the sensor/switch and disable or fix it.
Sean
96 GST 5 spd
SLoe is offline   Reply With Quote
Old 01-29-2006, 01:54 PM   #3
Myxlplyxxx
Myxlplyxxx Normal reputation
Try cking yer brake light switch that is activated by the brake pedal... if it is not getting touched by the pedal(has kind of a plunger type switch) then adjust the switch by screwing it in a bit til it does touch then ck to be sure u can hear the switch engage/disengage... had same problem on My 97 Lumina and I adjusted it in a bit.... but pull the harness wires off 1st as you cant move it more than 1/2 a turn without doing so.... bit of a pain too as it is under the dash.... Good Luck
MYX
Myxlplyxxx is offline   Reply With Quote
Old 01-30-2006, 03:27 PM   #4
travelair
travelair Normal reputation
First make sure the master cylinder resevoir is topped off with brake fluid. Rule out the easy fixes first right?
travelair is offline   Reply With Quote
Bookmarks
Google
Web AF
