idles rough in gearwtoombs 01-29-2006, 08:47 AM i have 1995 gcl which high miles but in good shape, just gave it a complete tuneup and relaced crank and cam sensor, now it idles rough in gear, fine in park, need some help. dksob81 01-29-2006, 09:17 AM sounds like the IAC might be bad or incorrectly adjusted. Try this, turn on the AC, place in gear and turn the steering wheel, does the RPM's drop significantly? - a sign of a bad IAC. wtoombs 01-29-2006, 09:23 AM thanks for the information, i will try this and see if it is the problem wtoombs 01-29-2006, 11:41 AM i thing this might be the problem. how do i adjust the valve or would it be better to replace it? dksob81 01-29-2006, 05:59 PM Replace it! and follow the instruction that come with the new sensor for adjusting the pintle. Bernando1 02-05-2006, 01:21 AM You can check the IAC, just get out a chilton book. My does the same thing. vibrates only when in gear, and at a stop. I think it has more to do with motor mounts myself. I think the rubber is wearing out, and causing more vibrations. My IAC was just fine. to check motor mounts you can look at them, and also have somone look at the engine and see if it rocks or torques excessively when you start the vehicle, or when you put it into gear. Let me know what happens. flykr2s 03-06-2006, 10:51 AM I have fought this problem for almost a year. I replaced every sensor possible on the car. I replaced all plug wires, dist cap, rotor, and everything else you can think of only to have the problem continue and it was worse in cold weather. Well I finally decided to replace the coil even though it checked out ok. That was the problem. Now my 93 JGC Laredo starts immediately and runs better than it has for years. Maybe I can get another 235K miles out of it. Tip of the day: REPLACE THE COIL. ccarball 04-12-2006, 05:15 PM Guys, thank you very much for the tip, I replaced the IAC and my Jeep Grand Cherokee 1993 runs as the first day. Another finding: - whne replacing the IAC ,You should disconnect the battery, for few minutes, give it half an hours, then change the IAC, plug battery back in, set to ignition, don't crank yet give it one or two minutes for computer to adjust (calibrate) the new IAC. Then Crank, I would take RPM to 1500, set the Drive Gear, pass it to neutral. it will jump down to 800-900 and voila! Automotive Network, Inc., Copyright ©2012
