hating my 1995 chevy lumina
Jessica1234
01-28-2006, 02:58 PM
this is sort of a long story, but i really need some help!! About a month ago my car started to overheat. It would go all the way into the red, and then cool down about 2 seconds later. I had the thermostat changed, and my radiator was flushed. when they lushed the radiator the fluid inside was orange. We then filled it with fresh anti freeze, and called it a day. well now the antifreeze is orange again, there is a lot of orangy brown chunky stuff in there and now antifreeze is spraying out by my motor, I tried sealing the leak with quick steal but it is still leaking a bit, someone PLEASE HELP. It really seems like this is a problem for a lot of lumina drivers. thankyou Jess
RahX
01-28-2006, 03:28 PM
if its an intake leak then bite the bullet and have it fixed. the brown chunky stuff is rust and youre probably never going to get that to stop. all you can do is flush it and flush it often. the rust may have clogged up your radiator or something else.
stgninja
01-28-2006, 03:52 PM
I don't mean to be funny but... are you aware that GM uses and recommends an anti-freeze that is orange in color? I personally do not use this stuff because I have been told by a GM mechanic that this stuff contributes to gasket failure.
RahX
01-29-2006, 02:18 AM
any coolant will eat gaskets if you dont flush it regularly. the biggest problems with dexcool are #1 color mixing and #2 air. if air is mixed with the dexcool for long enough it makes it scale up and get crusty and nasty. if its mixed with green coolant you might as well be making funky pudding.
danny1967
01-29-2006, 02:25 AM
have u tried flushing out the heater core do so, by diconnecting heater hoses, and i would flush the entire system with the engine running at normal operating temperatures. hope this helps.
Jessica1234
01-29-2006, 08:23 AM
I have already flushed the entire system, but there is still reddish orange chunk in there!! this car has given me nothing but headaches since I had the timing belt replaced. II don't know what I am going to do, I was hoping the prblem would just correct itself!:p But no luck yet!! Thank you for your help!
