brake pad replacement
9passport7
01-28-2006, 01:59 AM
I have a 97 passport, 4x4, 4wheel disc. It's time to replace my rear pads and was wondering there is any special tools or if it is a straight forward pad swap. I know that some vehicles require some extra large torx or ? I just haven't looked at it and I can't find my repair manual. Thanks for the help.
Canucklehead
01-28-2006, 07:34 AM
I have a 97 passport, 4x4, 4wheel disc. It's time to replace my rear pads and was wondering there is any special tools or if it is a straight forward pad swap. I know that some vehicles require some extra large torx or ? I just haven't looked at it and I can't find my repair manual. Thanks for the help.No special tools required, unless a c-clamp is considered special.
9passport7
01-28-2006, 11:27 AM
no i wouldn't consider a c clamp "special" :-) thanks thats all i wanted to know
rodeo02
01-28-2006, 12:02 PM
If I remember correctly- the rear calipers are a little funky on the <1998's. The pistons have to be rotated into, not compressed into the caliper bore. The threaded, rotating pistons have something to do with the parking brake actuation.
Joel
Canucklehead
01-28-2006, 12:21 PM
If I remember correctly- the rear calipers are a little funky on the <1998's. The pistons have to be rotated into, not compressed into the caliper bore.Nope.
surferfletch
01-28-2006, 05:51 PM
Yeah. The piston compresses straight in. This is a super easy job. You don't have to pull both pins to change the pads, but you ought to, and lube them really well. Don't forget to crack the lid on the master cylinder before compressing the piston.
rodeo02
01-28-2006, 10:02 PM
I'm mixing up a trooper vs. a rodeo :screwy: . I did rears on a pre 1998 troop that had the thread in caliper pistons. Kinda takes you by surprise.
Joel
maxl1961
02-01-2006, 03:30 PM
One question for gurus. When I change my 95 2WD rodeo brake pads, the 2 pins from the caliper were different. One with a black rubber ring on top of the pin, another one without it. May be I lost it? Is there any harm to the brake or caliper?
Thanks,
maxl
