Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > Tacoma
Old 01-27-2006, 11:56 PM   #1
oakfloor
oakfloor Normal reputation
3.4 cam belts
Has anyone here ever had one fail? my mechanic has never seen a broken belt on a V-6, and Ive talked to a guy with 169k on his 97' 3.4 and never replaced it...and has anyone ever had a water pump fail? if so how many miles? Thanks, LK
oakfloor is offline   Reply With Quote
Old 01-28-2006, 06:40 AM   #2
Flash75
AF - Advisor
Flash75 Normal reputation
Re: 3.4 cam belts
Does your mechanic recommend the belt doesn't need to be replaced? You didn't say how many miles you have on your truck, if it is over 90k you may want to think about your luck as a gambler. Read this Gates information for replacement intervals. Note that the Tacoma 3.4 engine is an interference engine meaning if the belt breaks you will probably have some internal engine damage.
http://www.familycar.com/CarCare/GatesFrame.htm
Regarding water pumps, you may want to read this article. If Tacoma water pumps never fail why would one dealer have 13 in stock?
http://www.automotiveforums.com/vbul...d.php?t=507014
FWIW, my Tacoma has a 2.4 engine with timing chain. I haven't seen a broken Tacoma belt but I did have to replace a broken belt on an Izuzu Stylus, lucky it was a non-intereferance engine.
Clifton
Flash75 is offline   Reply With Quote
Old 01-28-2006, 12:01 PM   #3
Brian R.
Resident Chemist
Brian R.'s Avatar
Brian R. Normal reputation
Send a message via Yahoo to Brian R.
Re: 3.4 cam belts
I don't know if you can draw much of a conclusion from the number of pumps in stock. Dealers routinely install water pumps in engines with timing belt replacement maintenance. Therefore, it is the timing belt change interval that determines, at least partially, the number of pumps replaced.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Brian R. is offline   Reply With Quote
Bookmarks
Google
Web AF
