window
billysandra
01-25-2006, 03:29 PM
I have a small air leak at the top of the driver's side window. It is pretty noisy when on the interstate. How do I adjust the window so it seals up firmly at the top of the window?
Thanks
AccordCodger
01-25-2006, 06:53 PM
Depending on the age of the car, you may be better off living with it. Having owned 3 Accords, I found they were ALL prone to wind noise at the top rear of the driver's door, and I think it has partly to do with the window frame.
mpumas
01-26-2006, 12:18 AM
Depending on the size, you can fix small leaks with black RTV2. Clean the rubber with solvent and put oil on the glass portion that comes in contact with the RTV. Fill the gap with RTV with the window not all the way up, then when it skims roll the window up as far as it goes.
