I would like to trash my abs system, can it be done?
lee308
01-25-2006, 10:09 AM
I want to ripe out the abs system and replace with non abs master cly. Can it by done and has anyone done it?
I figure the damn light can just stay on. Keep rear sensor for speed control only.
jd-autotech
01-25-2006, 10:48 PM
if you want to rerun the lines it can be done but its illegal to alter any brake system
lee308
01-26-2006, 11:06 AM
There is no inspection here, I'm tired of the sensor problems.
Would I have to swap all the lines or just the ones going between master cyl and abs garbage thing. I have a tubing bender so I won't kink lines.
way2old
01-26-2006, 11:28 AM
Inspection doesn't matter. If you alter the ABS system and have an accident,, an attorney will have a field day on the case. Just my 2 cents.
steve11
01-26-2006, 07:00 PM
are you talking about the idiot light on all the time??, take it out and throw it away.
lee308
01-26-2006, 09:31 PM
The damn ABS caused my first and last fender bender, in my last vehicle. Damn things actuated on dry level pavement at about 45 mph!!!!
I could have stopped with no problem without them.
james tibbals
02-12-2006, 12:11 AM
Unplug Abs in he front sensor that should shut it down. I had the same thing happen to my 97.
Millermagic
02-12-2006, 02:41 PM
I'm no fan of abs. Can't you unplug the fuse for it?
