Originally Posted by saturntangerine
Do you have the heater on during these times that you are describing? My parents looked at a Prius today (2005 model) and the salesman said that Toyota designed it so that when the car is "just" started and the heater is on that the gas motor turns on so it heats up faster. Toyota started this "feature" on the later generations of Prius because customers complained that the heat took too long to get going in the 1st generation models. Just a thought.
As for the 35mph part, I would guess that the gas engine might kick on during that time because the speed is consistent, which has better fuel economy than during accelleration. Again, I'm no expert, so I'm speculating here.
Yes and no on having the heater on. The engine will start and run for a short time soon after the intial start. Obviously it will keep running longer if the heater is on.
I'm not to certain on the 35 mph barrier, but your speculation sounds logical. I have been able to get ours up to 42 mph without the gas engine kicking in though. Not ever time mind you, but sometimes.
I just saw the 2005 models at the St. Louis Auto Show yesterday and I must say that I, in a fun way, am a bit peeved with Toyota now as the Prius now has Charcoal interior. It looks real sharp.
Regards
