radiator flush (GM Bulleton)bricvic 01-24-2006, 12:50 PM It's thorough, but kinda long. Anyway, hope it helps someone. Rust in Cooling System, Heater Inoperative, Blows Cold Air, Engine Overheats (Flush Cooling System) #99-06-02-012D 1996-2000 Chevrolet and GMC S/T Models (Blazer, Jimmy, Sonoma, S10 Pickup) 1998-2000 GMC Envoy 1996-2000 Oldsmobile Bravada with 4.3L V6 Engine (VINs W, X -- RPOs L35, LF6) Condition Heater is inoperative, blows cold air, engine may overheat or the coolant reservoir has rust in it. Cause Vehicles equipped with DEX-COOL® coolant, which may have been operated for extended periods of time with a low coolant level, usually in excess of 32,000 km (20,000 mi), may be susceptible to the formation of a rust-like material in the cooling system. Correction Flush the cooling system using the repair procedures that follow. Required/suggested parts and equipment for this correction. • 1 each *Prestone® Flush and Fill Kit #AF-KITP U.S. (#00050 in Canada). This kit can be obtained from your local parts supplier and can be used on all vehicles repaired under this procedure. • 1 each *Prestone® Heavy Duty Cooling System Cleaner, GM P/N 12346500. This cleaner is in powder form and contains a neutralizer. Do not substitute other cleaners. The diluted cleaners that are available in liquid form are not recommended for this repair. • 5.7 L (6 qt) of 100% (non-diluted) DEX-COOL® coolant (GM Spec 6277M). • 1 each new thermostat, GM P/N 12563335. • 2 each new radiator cap, GM P/N 15075565. • 1 each *Prestone® yellow funnel. This funnel can also be obtained from your local parts supplier. It fits snugly into the radiator opening for an easy fill and is reusable. *We believe this source and their products to be reliable. There may be additional manufacturers of such products. General Motors does not endorse, indicate any preference for or assume any responsibility for the products from this firm or for any such items which may be available from other sources. It is recommended the vehicle be placed in a position so that the following are available: • A sanitary sewer -- not a storm drain, etc • A monoxivent system (if the outside temperature is less than 10°C (50°F)). • Hot running water Notice Due to the complexity of these procedures, the following repair steps must be strictly adhered to in order to achieve the intended results. Any deviation or substitution may result in sub-standard cleaning/flushing results or system damage. Diagnostic Procedure 1. Install the Scan Tool. This will allow monitoring of the coolant temperature throughout the procedure. Notice As long as there is pressure in the cooling system, the temperature can be considerably higher than the boiling temperature of the solution in the radiator without causing the solution to boil. Removal of the radiator cap while the engine is hot and pressure is high will cause the solution to boil instantaneously - possibly with explosive force - spewing the solution over the engine, fenders and the person removing the cap. Under some conditions, the engine coolant is combustible. Important o The installation of a NEW radiator cap at the beginning of this procedure and the second new cap at the end of the repair procedure is necessary in order for the correct pressure to be achieved and for the repair to be completed successfully. o The radiator cap is NOT a good indicator of the general condition of the cooling system. Typically the underside of the radiator cap will exhibit a greater amount of contamination than the rest of the system. It is important to evaluate the condition of the cooling system by checking the following before beginning the repair procedure: 2. Remove the radiator cap. Install a new radiator cap, GM P/N 15075565. A properly operating radiator cap is essential for this procedure to work properly. Be sure to wipe off all radiator cap sealing surfaces prior to installation. 3. Start the engine. 4. Using a flashlight or lead light, look into the radiator. From the right side of the vehicle, peer into the radiator toward the left side of the vehicle. Observe the top three rows (or tubes) of the radiator. (It may be necessary to drain off some of the coolant to see the top three rows of the radiator). If it appears the coolant is able to flow through the third row down from the top, the vehicle should be repaired using Procedure A. If it appears the coolant is NOT able to flow through the third row down from the top, then the vehicle should be repaired using Procedure B. 5. Stop the engine. Repair Procedure A & B Important o If available, use coolant exchanger Pro-Fill 42-75100-KM, Power Flush 211-07601/DEX (available through the GM Dealer Equipment program), or equivalent to evacuate the system of coolant. Follow the manufacturer's instructions for exchanging used coolant with new coolant. However, for this procedure, use water in place of new coolant. Be sure to exchange 1½ times the cooling system capacity of the vehicle with water. This will ensure that only water remains within the cooling system. Once the coolant has been displaced with water, drain the water from the radiator. 2. Drain and properly dispose of the coolant. Caution Any obstructions in the hoses to or from the coolant recovery bottle may cause over-pressurization of the cooling system. This over-pressurization could result in serious personal injury. 3. Inspect the following hoses in order to assure there are no obstructions and the coolant is able to flow freely: o The hose to the coolant recovery bottle. o The relief hose from the coolant recovery bottle. 4. Disconnect both coolant hoses to the heater core from the engine. 5. Back flush the heater core for 5 minutes after clear water is present. Pressurized water not to exceed 345 Kpa (50 psi), may be used. 6. Reinstall the heater return hose to the engine. 7. Install the radiator cap and properly tighten. 8. Install the "T" from the flush and fill kit to a 25.4 cm (10 in) piece of 19 mm (¾ in) heater hose. Tighten the clamp. 9. Install the hose to the engine. Tighten the clamp. 10. Install the other end of the "T" in the heater core inlet hose. Tighten the clamp. 11. Disconnect the upper radiator hose from the radiator. Properly position the hose, so the accessory drive belt or any pulley/belt cannot touch the hose. 12. If you used coolant exchange equipment, disconnect it. 13. Attach a garden hose to the "T" of the flush and fill kit. Turn on the water and back flush the cooling system for at least two minutes after the water runs clear. 14. Start the engine and continue back flushing the cooling system for five additional minutes. 15. Turn the engine "OFF". 16. Turn the water "OFF". 17. Re-attach the upper radiator hose to the radiator. 18. Open the radiator drain and drain all water from the radiator. 19. Remove the lower left water pump crossover bolt. This allows lowering the water level in the left side of the engine. 20. After the water stops running from the water pump bolt hole, reinstall the bolt. 21. Close the radiator drain. 22. Mix the Prestone® Heavy Duty Cooling System Cleaner, GM P/N 12346500, in approximately 3 L (3 qt) of warm water. Pour the mixture into the radiator. Top off the system with plain water and reinstall the radiator cap. 23. Run the engine at 1600 to 1800 RPM with the air conditioning in the maximum cool position. To achieve the 1600 to 1800 RPM, place a dime between the closed throttle stop and the screw. This screw should never be adjusted, under any circumstance. Its only purpose is to keep the throttle plate from sticking in the bore when the throttle is slammed shut. It is not a minimum idle (RPM) control adjustment screw. Important It is imperative that all air pockets have been removed from the cooling system in order for the cleaning procedure to be effective. Service Procedure A For Service Procedure A, the cleaner should be left in the system for three hours (after normal operating temperature of the cooling system has been achieved). Normal operating temperature is when the coolant temperature stabilizes around 98°C (200°F). The best results are obtained when the coolant temperature is between 98°C (200°F) and 110°C (230°F). DO NOT EXCEED 113°C (235°F). Use the Scan Tool to determine when this point has been reached. When this temperature has been reached, start the clock. Periodically (every twenty minutes or so), monitor the coolant temperature and engine during the three hour run time. In order to achieve a constant temperature of 98°C (200°F) to 110°C (230°F) during this procedure, maintain the idle speed, turn on the A/C or partially close the hood. Service Procedure B For Service Procedure B, the cleaner should be left in the system for two and a half hours (after normal operating temperature of the cooling system has been achieved). Normal operating temperature is when the coolant temperature stabilizes around 98°C (200°F). The best results are obtained when the coolant temperature is between 98°C (200°F) and 110°C (230°F). DO NOT EXCEED 113°C (235°F). Use the Scan Tool to determine when this point has been reached. When this temperature has been reached, start the clock. Periodically (every twenty minutes or so), monitor the coolant temperature and engine during the two and a half hour run time. In order to achieve a constant temperature of 98°C (200°F) to 110°C (230°F) during this procedure, maintain the idle speed, turn on the A/C or partially close the hood. Important The vehicle should not be left idling outdoors when the ambient temperature is below 10°C (50°F). The flushing procedure relies on heat as a catalyst in order to be effective. Ambient temperatures below 10°C (50°F) do not allow sufficient cycling of the thermostat to effectively clean the cooling system. 24. Turn off the engine. 25. Remove the dime from the closed throttle stop screw. Do NOT remove the radiator cap. Following the procedure listed below will assist you in draining the cooling system thoroughly. o Place a drain pan under the radiator drain hose. Caution The cooling system and coolant are hot and under pressure. Loosen only the radiator drain until the pressure has been released from the cooling system and follow the procedures exactly in this bulletin, using normal safety precautions to avoid being injured by the hot coolant mixture. Loosen the radiator drain. Drain approximately 1 L (1 qt) of liquid from the system. o After the pressure has been released from the cooling system, slowly loosen the radiator cap to the safety stop. Do not remove the cap (This releases the spring pressure on the secondary seal while retaining the primary seal to the top of the filler neck and will allow the coolant reservoir to be evacuated). o When the coolant reservoir is empty, re-tighten the radiator cap fully. o Remove the cap from the flush and fill "T". This will allow the coolant to be siphoned from the heater core and the engine block. o When the water has stopped coming out of the radiator drain hose, close the radiator drain. Do not place the cap on the "T". 26. Using Prestone® Heavy Duty Cooling System Cleaner, GM P/N 12346500, mix the neutralizer (from the bottom of the can) with approximately 3 L (3 qt) of warm (shower temperature) water. Notice Do not put cold water into a hot engine as engine damage may occur. Under no circumstances should the neutralizer be left in the cooling system for any longer than ten minutes once the vehicle has reached operating temperature (thermostat open). The neutralizer is corrosive to aluminum and will damage system components if it is left in the cooling system for longer than ten minutes. 27. Pour the mixture from the step above into the radiator. 28. Completely refill the cooling system with warm to hot water through the "T". When the radiator is full, install the radiator cap to the safety catch. Continue to fill until the overflow reservoir is filled to the hot line on the reservoir. 29. Remove the fill hose and install the cap on the "T" and the radiator fully. Importent It is imperative that all air pockets have been removed in order for the procedure to be effective. 30. Start the engine. After engine speed stabilizes, reinstall the dime between the closed throttle stop and the screw. With the A/C on, bring the cooling system back to normal operating temperature and follow the directions on the can. 31. Turn off the engine. 32. Remove the dime from the closed throttle stop and the screw. Caution As long as there is pressure in the cooling system, the temperature can be considerably higher than the boiling temperature of the solution in the radiator without causing the solution to boil. Removal of the radiator cap while the engine is hot and pressure is high will cause the solution to boil instantaneously - possibly with explosive force - spewing the solution over the engine, fenders and the person removing the cap. 33. Drain the cooling system, following the procedure listed in Step 24 above. 34. Do not close the radiator drain. Leave it open. 35. Disconnect the upper radiator hose from the radiator. Properly position the hose, so the accessory drive belt or any pulley/belt cannot touch the hose. 36. Attach a garden hose to the "T" of the flush and fill kit. Turn on the water and back flush the cooling system for at least two minutes after the water runs clear. 37. Start the engine and continue back flushing the cooling system for five additional minutes. 38. Turn the engine "OFF". 39. Turn the water "OFF". 40. Close the radiator drain. Important If the repair is a Procedure A, go to Step 40. If the repair is a Procedure B, remove the radiator and have it recorded and steam clean the end tanks. After reinstalling the radiator, continue to Step 40. 41. Remove the air cleaner housing and tube assembly from the throttle body. 42. Remove the two nuts holding the throttle cable bracket to the throttle body and position the bracket and the cables out of the way. 43. Remove the thermostat. 44. Remove the previously installed flush kit "T" and hose. Save for future use on other vehicles. 45. Install the heater inlet hose to the intake manifold and secure with the original spring clamp. 46. Inspect the thermostat opening and cover for foreign material. Clean if necessary. 47. Remove the left lower water pump crossover bolt to drain the left side of the block and the left cylinder head. 48. Install sealant to the bolt threads, using GM P/N 12346004 (Canada GM P/N 10953480), or equivalent and reinstall the water pump crossover bolt. Tighten Tighten the bolt to 41 N•m (30 lb ft). 49. If available, use coolant exchanger Pro-Fill, Power Flush, or equivalent to fill the system with 50/50 DEX-COOL® coolant. If a coolant exchanger is not available, proceed to the next step now. Follow the manufacturer's instructions for system fill/coolant exchange. If you are using coolant exchange equipment, you will need to install a new thermostat, GM P/N 12563335 and top off the system with clean drinkable water prior to exchanging. After exchanging, install the upper radiator hose and clean out the coolant recovery bottle. Proceed to Step 56. 50. Pour 5.6784 L (6 qts) of 100% (not pre-mixed) DEX-COOL® coolant into a clean container. 51. Using a clean funnel, pour as much of the 100% DEX-COOL® coolant that you can into the engine through the thermostat opening. 52. Install a new thermostat, GM P/N 12563335. Tighten Tighten the bolt to the specified torque of 19 N•m (14 lb ft). 53. Hold the upper radiator hose in the straight up position and pour 0.473 L (1 pint) of the 100% DEX-COOL® coolant into the hose. 54. Install the upper radiator hose to the radiator and properly position the clamp. 55. Flush the coolant recovery bottle thoroughly. 56. Complete the fill of the cooling system with the balance of the 5.7 L (6 qt) of 100% DEX-COOL® coolant and top off with plain water. If the water is not drinkable, do not use. Water must be clean and fresh. Important The second new radiator cap must be installed at this point of the procedure. It is possible that small contaminants may have become lodged in portions of the first cap during the cleaning procedure. 57. Clean the radiator cap sealing surfaces on the radiator. Install the radiator cap, GM P/N 15075565. Important It is imperative that all air pockets have been removed in order for the cooling system to function properly. 58. Run the engine to operating temperature with the air conditioning in the maximum cool position for ten minutes. Caution As long as there is pressure in the cooling system, the temperature can be considerably higher than the boiling temperature of the solution in the radiator without causing the solution to boil. Removal of the radiator cap while the engine is hot and pressure is high will cause the solution to boil instantaneously - possibly with explosive force - spewing the solution over the engine, fenders and the person removing the cap. Under some conditions, the engine coolant is combustible. 59. Turn the engine "OFF" and let it cool. 60. Check the coolant concentration for a 50/50 mix, using refractometer J 26568 (Centigrade scale) or J 23688 (Fahrenheit scale). Follow the manufacturer's directions for using the coolant tester. Unless your coolant tester has a provision for temperature correction, it is imperative that the correct coolant temperature is achieved when testing the coolant. If the coolant is warmer or cooler, the reading may be incorrect. 61. Top off the radiator and fill the coolant recovery bottle to 2.54 cm (1 in) above the full hot mark on the coolant reservoir. Add the appropriate coolant mixture to come to a 50/50 mix of the DEX-COOL® coolant. Parts Information Part Number Description 12346500 Prestone® Heavy Duty Cooling System Cleaner 12563335 Thermostat 15075565 Radiator Cap Parts are currently available from GMSPO. Warranty Information For vehicles repaired under warranty, use: Labor Operation Description Labor Time J3700 Cooling System - Flush 3.1 hrs Add Time for Procedure B 0.5 hr Automotive Network, Inc., Copyright ©2012
