Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Astro > M Bodies
Old 01-23-2006, 09:01 AM   #1
drew300
drew300 Normal reputation
Batt light
I haven't had time to trouble-shoot, and it was dark by the time i got home.
Does any-one have advice on this fault?
The battery was down, as I don't drive the van much. After about a half hour drive, I floored the van, it accelerated well, but I caught a flicker on the dash. It drove fine. I tried hard aceleration again, and I saw the Battery Light flash momentarily. It ran fine, and the dash voltmeter said around 14.2 maybe 14.4 V.
I had no trouble on the way home, but I'd rather have a small problem than wait for a big one.
The fan belt is only about 5,000 Km old, so it should be good. And the tensioner was good, last time I looked. At idle, the voltage stayed up when i turned on/ off the lights, however, at idle for around a minute, the dash guage read about 13.8 or so. It had been about a month since I drove it, maybe corrosion on the slip rings?
Ideas?
Thanks
drew300 is offline   Reply With Quote
Old 01-23-2006, 01:57 PM   #2
scottnhalifax
scottnhalifax Normal reputation
Re: Batt light
sounds about right with voltage, just as long as when all acc are turned on you should still draw 13 or so volts fromt he altenator.
with the battery light comming on when you floor it it may be your alternator cant keep up and it is ont he way out
but if it was me just drive it till it wears out
scott
ps a 14 volt charge with no acc on is ok , thats what i have
01 venture.
scottnhalifax is offline   Reply With Quote
Old 01-29-2006, 04:43 PM   #3
Kings-x59
Kings-x59 Normal reputation
Re: Batt light
clean the battery terminals, and make sure the cable connections are tight.
'89 Astro 4.3L Z
CFM-Tech power plate
2.5" exhaust, Low restriction cat and muffler
Jet stage I chip
B&M trans cooler
'96 Jeep Cherokee
'99 Chevy Cavalier
Kings-x59 is offline   Reply With Quote
Old 02-02-2006, 11:58 AM   #4
stephensonjr
stephensonjr Normal reputation
Re: Batt light
As a related followup to the original question.
I just replaced an old battery with a brand new one. The battery light now stays on continuously and the dashboard voltmeter is reading about 10volts
Jim Stephenson
Long Island, NY
2000 Plymouth NEON
1997 Ford Contour
2005 Ford Explorer
2000 Starcraft 17CK Camper
stephensonjr@optonline.net
stephensonjr is offline   Reply With Quote
Old 02-02-2006, 01:27 PM   #5
scottnhalifax
Re: Batt light
time for a new altenator no question about it
enjoy
scott
01 venture.
Old 02-13-2006, 03:52 PM   #6
drew300
Re: Batt light
I think I may have found the fault. I took the battery out to check it, and found a shorted cell, according to my fancy computerized battery charger.It was down to 10% charge, and it isn't coming up. I'm surprised it started well.
Curious, I bought this van used, but it had a Sears Die-Hard in it. So it's gone thru the original, and a 2nd battery, and it will be on it's 3rd battery. It's only a '97 van.
Bookmarks
Google
Web AF
