neon...stumble??
telamonkinslaye
06-17-2002, 02:49 AM
i have a 1998 dohc and it just started "stumbling" i think, it feels like its losing power and dropping off and quickly gaining it back during acceleration, and if i press harder it can croak. i've read of many problems that can cause it, i was wondering if anyone might have had a similar one, and could someone please please explain to me what exactly a stumble is?
thanks in advance.
telamonkinslayer
KatWoman
06-20-2002, 12:29 PM
Hmmm. Check and see if you are throwing any codes. Go here to see how to get codes:
http://www.neons.org/neontsb/diagnost.htm
Then tell us what codes you are putting out if you are.
telamonkinslaye
06-21-2002, 09:16 PM
i tried it, and it came up with normal.... now my neon dies when i turn right after a cold start....?
KatWoman
06-24-2002, 03:31 AM
Hmm, how many miles are on your car?
Some things I would check would be:
spark plugs/wires - possible bad coil pack (depending on your mileage)
fuel system - you may need a new fuel filter or fuel injection service
camshaft postion sensor - check the left side of the motor near the valve cover and see if there's any oil leaking or oil sludge...that's a sign of it going aside from the stumbling
wiring going from the battery - especially if you have a Chrysler battery that leaks that acidy crap...check power wire to make sure it isn;t corroded
check by your throttle body,make sure no hoses are interferring with the throttle (accelerator) cable
Also when your car loses power, do your lights/accessories still come on or does the whole system die?
Doc61199
08-09-2002, 06:25 PM
Yo, make sure ur ac isnt in......my car does the same thing when its on:(
