Digmoto Lite on Jeepshoofan 01-22-2006, 07:48 PM Folks, Has anyone used this on a laptop with Jeep (Mine is a 1996)? Also, do you know if it is OK to use just a OBDII to Serial cable like the one linked below (Item #10 down the page)? http://www.digimotosales.com/shop/?shop=1&cart=37858&cat=1&noCookiePassThrough=Y& I want to be sure before I give this a try. I want to be able to drive and record info at the same time... Thanks, Bryan PMDresurrected 01-23-2006, 02:26 AM I don't know, that place looks a little scarry if you ask me.. Would you plug your lap top into your PCM? Do you plan on getting this? LOL more I look at it the more I want it.. hoofan 01-23-2006, 10:23 AM I downloaded the free software. The question I have is the cable itself. The cable shows a serial to OBDII interface that could effectively plug right in the same as you would a scan tool. However, some things I read mention something about an "interface" of some kind that is needed too, so I'm confused. I just don't want to buy more than I need. Bryan bringselpup 01-23-2006, 02:39 PM I think the graphic on this site looks like it will explain better what is going on. http://www.scantool.net/products/elmscan_iso.htm PMDresurrected 01-24-2006, 03:16 PM It's to bad you have to use the interface, seems to me you should be able to just use your computer and a cable, or even a Bluetooth. 2006 is not what 2006 was going to be in 1980. Automotive Network, Inc., Copyright ©2012
