Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Honda > Accord/TSX/Accord Hybrid
Old 01-22-2006, 07:38 PM   #1
ude_loose
ude_loose's Avatar
ude_loose Normal reputation
Send a message via Yahoo to ude_loose
1990 Accord 5Spd:Help Locating Idle Control
I have a 1990 Accord 5 spd, when i turn it on and its cold or warm outside it accelarates by it self in a way that the rpm's go up come down and go up again constantly even when i drive around everytime i stop it does it again, i was told it can be the idle control, i want to know where this is located and how to replace it...Thankz
ude_loose is offline   Reply With Quote
Old 01-23-2006, 11:53 PM   #2
redly1
redly1 Normal reputation
Re: 1990 Accord 5Spd:Help Locating Idle Control
not sure how relavant this is, but my 93 accord (auto) was doing the same thing (only when cold, though...but up and down about 800RPM between 1500 and 2300...really annoying) . Replaced the O2 sensor this last weekend, and it doesn't do it anymore. Got a nice ~3MPG bump in mileage from it too!
redly1 is offline   Reply With Quote
Old 01-28-2006, 01:24 AM   #3
xtreme barton
xtreme barton Normal reputation
your car doesnt have one.
try looking into your map sensor ...
if forget if you can test those with a multi meter to see if they are operating correctly... but i do know new ones are about 175 dollars..
xtreme barton is offline   Reply With Quote
Old 01-28-2006, 01:25 AM   #4
xtreme barton
oh the way..
www.autozone.com
under component
Old 01-29-2006, 11:03 PM   #5
Pedro F
Pedro F Normal reputation
Send a message via AIM to Pedro F
yeah you should have one and it should be located right next to you're throtle body in;et it's a flat head screw, but thats not you're proble, you;re problem is that you're FIAV(fast idle air valve) located net to the IAC(idle air controler) is busted needs replacement, hapened to me only when the car wsa cold during sumer them whenit warmed up it would be fine. Now in the winter time it would do it all the time so I replaced it with known good one problem went away.
Pedro F is offline   Reply With Quote
Old 01-30-2006, 12:07 AM   #6
xtreme barton
i stand corrected !! you do have one.. thanks pedro f !!
i checked on autozone.com and said no part ..
looked it up on partsamerica.com and it showed up ...
expensive though !!
Bookmarks
Google
Web AF
