How do I change a rear stud?Attworth 01-22-2006, 06:15 PM Does anyone know how to change a rear stud on an 04 1500? Whomever put the aftermarket rims on, crossed one and decided not to fix it. Well, I have to now. Advice? MT-2500 01-22-2006, 07:04 PM Tou will need to remove the brake drum or rotor. Drive the old one out and pull the new one in. Piece of cake job. MT Attworth 01-22-2006, 07:13 PM Thanks MT. I did not look close to see if it was a one-piece set up or pressed in. Thanks. MT-2500 01-22-2006, 07:39 PM If it has disk brakes you will have to remove caliper and pads then the rotor should come off the axel. Knock old stud in and out. New one should pull back in with placing some washers and lug nut one it. MT Automotive Network, Inc., Copyright ©2012
