outside window trim for 95 civic dxvbcamry 01-22-2006, 12:14 PM does anyone know the best place on line to purchase the outside window trim for a 95 civic? mine has gotten dry rotted and needs replacing. Is it hard to replace? Thanks CivicSpoon 01-22-2006, 12:57 PM www.slhondaparts.com (http://www.slhondaparts.com) (if that doesn't work, try www.slhonda.com (http://www.slhonda.com) and go to the parts section of the site) www.hondaautomotiveparts.com (http://www.hondaautomotiveparts.com) What pieces are you talking about exactly, the piece that's right below the window? If that's it, then I believe you just pry it up with a flat head screw driver. Pavlo 01-22-2006, 06:50 PM I sprayed mine with truck badliner, looks ok. Planning on sanding it, then bondo to get it smooth and spray with flat black. But ill see. Automotive Network, Inc., Copyright ©2012
