Fog lamp troubleshootingramseyjack 01-21-2006, 10:41 PM 1995 Ranger 6 cyl extended cab. When I attempt to turn on the fog lamps (low beam on), I get no indicator at the switch to the right of the radio, and no voltage to the fog lamps. The fuses appear OK and the "fog lamp relay" in the power distribution box in the engine compartment, properly "clicks" when switch from high to low beam. Anyone run into this one? Thanks, Jack 2000mudder 01-22-2006, 01:37 PM both of mine burned out and the light on the switch wouldnt come on. maybe bulbs are burned out? ramseyjack 01-22-2006, 02:25 PM That could be a possibility. I had already ordered a new foglamp assembly for the passenger side. (broken). Should arrive sometime next week.I did not know you could take them apart and replace the bulbs. Thanks Jack Automotive Network, Inc., Copyright ©2012
