Blower motor fixmancur 01-21-2006, 04:47 PM Just wanted to thank Bnaylor, jr6078, and others who've been so kind to post descriptions of this fix. I just got through fixing the infamous dead AC/Heater problem (dead on all settings). A quick rundown of how it went for me: First, the fuse by the passenger door was fine, however Fuse #53 (30A) under the hood was blown. Replacing this fuse got the highest fan speed setting to work, but all others still remained dead. So, on to the blower motor resistor. GM appears to have changed the part number...my dealership no longer carries #15359314, but instead #89018413 ($23). As described, it's located under the passenger dashboard, way back against the firewall. You remove a couple of plastic covers to get access, then there's a square black plastic module that you can "slide" to the right to get out of the way. The resistor is held in with (2) 7/32" screws. I found an extra 6" extension on my ratchet to be a great help (in addition to the universal joint and 4" stock extension). Removed it. Installed the new one. Put everything back together, and all fan speeds now work. Start-Finish time was just about 1 hour. Thanks again all. BNaylor 01-23-2006, 08:33 AM Good job! You are welcome and glad you got it resolved. AleroDude69 01-28-2006, 05:49 PM hey ya today was the day my heat and air did not work. My blower was not even working to my dismay i got a new resistor and while putting it in my touched the plugin to the blower and it kicked on and off so i wiggled it more and found out that the connection was bad on the blower motor nothing a lil duct tape would fix lol osubuckeyes 02-08-2006, 01:19 PM I would just like to thank and show a little empathy for all of you who write in and talk about the same problems I'm having with my 2001 Alero. It has been a great help knowing I'm not the only one having these problems and seeing how they can be fixed without having to go to a dealer and pay outrageous fees. THANK YOU! anemo21 03-30-2006, 01:11 PM I just wanted to thank bnaylor3400 and mancur for the info on the blower fan resistor fix. I have a 1999 Alero and had this done once under warranty the second year I had it. They apparently replaced the OEM 15359314 with a 15369330 made on 6/29/00. This new one promptly died within 6 months of the 3 year car warranty running out! I did'nt know how costly it might be at the dealer so I held off having it fixed and lived with a two-speed fan until I read your fix. I did the repair myself in about a back-breaking hour (next time I WILL remove the passenger seat first!). It was a bear getting the last screw in but a delight to have all speeds working again. I might add that the replacement board is longer than the oneI pulled out but no problem, the new one had plenty of room in the space. Thanks again to all. PS: Still love the car! It's gonna break my heart to trade her this year! BNaylor 03-30-2006, 04:03 PM I just wanted to thank bnaylor3400 and mancur for the info on the blower fan resistor fix. I have a 1999 Alero and had this done once under warranty the second year I had it. They apparently replaced the OEM 15359314 with a 15369330 made on 6/29/00. This new one promptly died within 6 months of the 3 year car warranty running out! I did'nt know how costly it might be at the dealer so I held off having it fixed and lived with a two-speed fan until I read your fix. I did the repair myself in about a back-breaking hour (next time I WILL remove the passenger seat first!). It was a bear getting the last screw in but a delight to have all speeds working again. I might add that the replacement board is longer than the oneI pulled out but no problem, the new one had plenty of room in the space. Thanks again to all. PS: Still love the car! It's gonna break my heart to trade her this year! You are welcome. Glad you got something helpful out of our humble forum. Tilimiritryamdia 04-17-2006, 12:34 PM Hi. I think ,this information will be useful . After 2 lower blower speeds stopped to work 3 monts ago I had fixed my old blower motor resistor using a soldering iron . I found ,that similar ACDElco "patch" exists on blower resistor from beginning (4.5 years) and did one more "patch". The blower motor is still Ok. I believe , it will work more.. YamTZ750 10-25-2006, 04:31 AM Remember to check resistor's electrical connector terminals for corrosion. The excessive resistance will certainly cause circuit board solder to overheat. Clean terminals and apply a bit of dielectric grease to help prevent corrosion. BNaylor 10-25-2006, 08:23 AM Remember to check resistor's electrical connector terminals for corrosion. The excessive resistance will certainly cause circuit board solder to overheat. Clean terminals and apply a bit of dielectric grease to help prevent corrosion. YamTZ750, Welcome to AF and thanks for sharing your experiences. Please check the date of the last post and if over 3 months old do not resurrect it. Thread closed. POSTING IN CLOSED OR OUTDATED THREADS: If a thread has been closed, there is probably a logical reason for it. If you feel that the reason(s) for closure of the original thread are unjustified or wish further clarification feel free to contact any member of the moderating team. However, do not start a new thread about another closed thread. Please avoid posting or voting in outdated threads. It merely clutters up the message board and makes it more difficult for fellow members to sort through the vast amount of information contained on the boards. If you have new and important information to add regarding a past discussion, feel free to start a new thread and if need be, add a link to the original thread. vBulletin®, Copyright ©2010, Jelsoft Enterprises Ltd.
Automotive Network, Inc., Copyright ©2010
