Re: Rear Wiper Out 98 Astro
Check fuses, and does the washer work?
I've found that most wires break at the bends. If the fuse and switch are ok, I'd look at the rear hatch.
i've used a pin to penetrate the insulation and check for voltage.(with a meter) Just tape up the hole so it won't rot in future.
I've had trouble with the "parking switch" on the wiper motor also. It's sort of like a microswitch usually.
But not having fixed one on an Astro, that's about it from me.
