Daytime Running Lamps
Peter99
01-17-2006, 03:20 PM
2001 Exp EB. I got this car used and I am try to find out if it has Daytime running lights. The haynes manual specifies a DRL relay but I'll be dammed if I can find it or where it is supposed to be located. Does any one know? I do have a empty relay socket in the junction box under the hood but no indication as to what it would be.
xterracraze
01-17-2006, 05:12 PM
I have a 2001 Exp, but however it is not an Eddie Bauer edition, mine does not have daytime running lights, but more than likely because you have an "upgraded" exp. you may, but I'm sure that it doesn't.
bertexpy
03-10-2006, 09:55 AM
HI
DO YOU KNOW IF YOU HAVE ALL THE SWITHES
I HAVE A 97 EDDIE BAUER
AND THE DAYTIME RUNNING LIGHTS AND THE SWITH IS ON THE LEFT SIDE OF THE STEERING WHEEL ON THE DASHBOARD NEXT TO THE INSIDE LIGHTS
ITS LIKE A DIMMER SWITCH YOU TURN IT ON OR ADJUST
ITS NEXT TO THE HEADLAMPS SWITCH
:icon16:
