Blower Motor - Plymouth Breezelduncan 01-17-2006, 10:25 AM I have a 1999 Plymouth Breeze. About a month ago, settings 1-3 on the heat/cool fan stopped working. Only setting 4 worked. I was told that it was most likely the blower motor resistor. I replaced the resistor and regained use of the first 3 settings. Now, about a month later, setting 1-3 are gone again. So, I'm assuming the blower motor needs replacing (and another resistor)??? Where would I find detailed instructions (including pictures) on how to do this myself? vanco27 01-18-2006, 10:52 AM It is The blower relay switch. typical problem With mopar. It is located behind the glove box you dont even have to remove any thing to get to it. its a tight area but it can be done . the part will cost you about 30 bucks. Hope this helps stanmannus 02-24-2006, 10:36 AM Where on the Breeze/Stratus is the blower motor resistor located? lduncan 02-24-2006, 10:55 AM It's behind the glove box (see previous note above). Here are 2 links that were helpful to me: http://autorepair.about.com/library/faqs/bl705e.htm and http://autorepair.about.com/library/a/1g/bl702g.htm. stanmannus 02-24-2006, 11:52 AM That is exactly what I need! Thank you very, very much. :grinyes: stanmannus 05-24-2006, 08:46 AM Mine keeps popping. The resistor block for my '99 Stratus is $40Cnd from the dealership. I'm going to replace the motor this time. Can anyone provide a little insight into the blower motor location & possibly the steps required to replace it? I picked up replacement thermal fuses for $2.50 each, sure beats the $40 resistor block. But i still want to replace the motor. All I need is a rough location to start look for it. Thanks again for previous help. Automotive Network, Inc., Copyright ©2012
