Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer
Old 01-14-2006, 01:22 PM   #1
blkmonday
blkmonday Normal reputation
95 boggs down on acceleration
ok heres my situation...i have a 95 astro with a 4.3 (theres not that many astro posts so since its the same setup i thought id try here) my problem is a rough idle and it boggs down on acceleration...it lacks serious power. ive replaced so far
fuel pump and strainer and filter
ignition module
ignition coil
plugs/cap/rotor and wires
air filter
also cleaned the egr valve
the fuel pressure is higher now with the new pump...so i dont feel replacing the pump was a waste of time. however it still runs like a 77 dodge with a zillion miles on it.
what should i look at next?
blkmonday is offline   Reply With Quote
Old 01-14-2006, 01:32 PM   #2
blkmonday
Re: 95 boggs down on acceleration
oh i forgot to mention...90k miles and no engine codes! nice computer these things have right?
Old 01-17-2006, 01:30 AM   #3
wolfox
wolfox's Avatar
wolfox Normal reputation
Send a message via Yahoo to wolfox
Check base engine timing.
Make sure that your CPI is working properly. (Fuel pressure leak-down test)
Perform a complete engine compression test on all cylinders and a leak-down test there too. (All cylinders should be within 10% of one another to be considered healthy)
If the CPI passes leakdown testing and you know you have no mis-fires, try running an SUV sized bottle of Techron through the fuel tank, you may just have dirty injectors, ring faces and valve seats.
wolfox is offline   Reply With Quote
Old 01-17-2006, 11:19 AM   #4
joehfd
joehfd Normal reputation
I have a 95 blazer also had the same problem 1 was the fuel regulator and the 2nd was i had clogged cat converter it runs about $150.00
joehfd is offline   Reply With Quote
Old 01-17-2006, 11:29 AM   #5
laxman21
laxman21's Avatar
laxman21 Normal reputation
Sounds like a clogged catalytic converter.
'92 s-10 4x4 EC p/u
'99 Blazer LT
'99 Suburban LT
laxman21 is offline   Reply With Quote
Old 01-17-2006, 11:58 AM   #6
wolfox
wolfox's Avatar
Hadn't thought of that Catalyst. Good points, people.
Bookmarks
Google
Web AF
