Diagnostic Help....CVjoint, wheel hub, or....
rbajjk
01-13-2006, 02:55 PM
Thanks in advance for your expertise....
Here's the situation:
1997 Aurora, ~114k miles, owned myself for 2.5 yrs, most of the last 60k miles are mine and highway.
I have a slight roar/rumble from the front driver's side. However, this roar is ONLY when I turn right and have my foot on the gas. This sound goes away when either I remove my foot from the pedal or straighten out. This does not occur when I turn left. This sound is not metallic, metal to metal, nor does it seem to have any vibration associated with it. It does rumble louder as I push on the pedal (the harder the acceleration). I believe the sound has gotten more pronounced over the last couple of months. I do not have any other steering issues.
I have not noticed any fluid from the rubber cv boot, but do need to look more closely. This is definitely NOT the struts, as they were worn and I replaced them recently - the sound was there before and after the install.
Any ideas?? Is this anything to worry about as the suspension/steering is not being affected (yet?????)?
Also, what are the potential costs/efforts to fix what you believe to be the problem? Are these diy land?
Thanks for your thoughts.
Brian.
jim56
01-14-2006, 01:32 AM
Brian.
Good luck, my 97 had the same problem for the last 30,000 miles that i had it....never could find out what it was........finally traded it for a town car at 140,000...............
boldsmobile
01-15-2006, 11:20 AM
Sounds like your wheel bearing. Noise on left side when turning right is due to weight transfer of car to left side.
I had one go bad, its not too bad of a job but the bearing is part of an assy and seem to recall it costing about 150.
Good luck.
zimaad
01-15-2006, 02:43 PM
Did you replace the strut bearings when you changed the front struts? These typically go bad and can lead to some click/popping and possibly some roaring. Also, is it at lower speeds, what about in parking lots turning into spaces? There is a known problem of an improperly designed power steering hose that causes a roar/vibration. I wouldn't say it would get worse though. Check to make sure you don't have any wheels rubbing anywhere.
just some ideas to be added to the hub assembly. That's a good thing to look at also.
