Urgent Help Needed!!bmwchika 01-13-2006, 01:20 AM Okay so i have a 1989 750iL that i acquired from someone. It ran fine for a while but my dad started noticing some problems. He found out that i needed to change the water pump. We changed that then heard a loud ticking noise. changed the tensioners now sounds much better. But the car runs really hot. THe person who gave me the car said that it usually ran around 1/2 but now it runs around 3/4 sometimes more. Any ideas on how i can fix this or what could be wrong? What type of coolant should be used? thanks so much. Bear 01-22-2006, 03:04 PM I had a 1988 750 until last May (sold it) however we need more info on the running hot issue. It could be that the coolant needs to be bled, but most of our 750s are self bleeding ( mine was). Does she overheat at idle and at speed or just at idle? If she overheats at idle only, I would suspect the fan clutch needs to be replaced. As to coolant, I used ZEREX G-05, it is the product used by Mercedes, Volkwagen, Audi and is available at PEP Boys, Auto Zone to name a few. With the factry thermostat the temp gauge needle should sit about one needle width to the right of 12:00 O'Clock (195 degrees "F"). LeadOneFoot 01-22-2006, 04:40 PM I am thinking that if ya changed the water pump ya better change the thermostat at the same time. Look into that... bmwchika 01-23-2006, 12:02 AM thanks guys you guys are such a big help. i found out it was my auxillary fan! luckily i found a replacement..cheap en still new. LeadOneFoot 01-23-2006, 12:28 PM Well hey thats good, the fan was not kicking on or something? Good luck and where did ya get the new parts from? Bear 01-23-2006, 04:18 PM So was it the fan motor, fan resistor, or fan temp switch? bmwchika 01-23-2006, 11:22 PM the fan wasnt turning on at all. so i found out it was the fan motor that needed to be changed. some lady on ebay that i bought another part from sold it to me for cheap. does neone noe how to take of the door panels? im having a problem with my passenger door locking.. Whitese7en 02-17-2006, 01:51 PM bmwchika, try the link below. I'm not sure if it directly has information on door panels but there are many other links within this link with a wealth of information, which may be helpful. Good luck!! http://tridem.han-solo.net/auto/erich/auto.htm ron4cow 03-05-2006, 10:15 PM try this site it will give alot of info. ron4cow 03-05-2006, 10:18 PM try this site it will give you alot of info. i have an 88 750il it help me alot. http://bmwe32.masscom.net/ and you planing to do mantanance by yourself a will suggest you to buy the bentley repair manuel. $120 at borders or try ebay will be less but it worth it. Automotive Network, Inc., Copyright ©2012
