Re: Help with egr valve (rough idle when warm)
You need a vacuum pump to test both of them.
EGR Valve: Ignition off, hook up a vacuum pump to the valve and apply vacuum (15 or 20 inches). It should hold the vacuum. If not, replace. Start engine, the vacuum should go to zero. If not, replace.
Solenoid: Ignition off, apply vacuum to TBI side. It should hold vacuum. If not, replace. Ignition on, engine off, jumper terminals A and B on the ALDL connector and you should see vacuum on the EGR side of the solenoid.
By the way, I have the 90 service manuals and just tested my EGR valve and solenoid on my 90 K1500. In my case, the solenoid would not hold vacuum so I replaced it.
//2000CAYukon
