E39 528i Steering Wheel Shakes when Breaking
sgtbello
01-12-2006, 06:10 PM
Hello,
My E39 528i steering wheel has started to shake when breaking. Sometimes it’s more apparent then others. The wheel will move from side to side in a fast jittery motion and then generally stops as speed slows.
I was wondering if anyone else has had a similar problem or a solution.
Thanks in advance.
Misha1973
01-15-2006, 06:36 PM
I had to replace lower front control arms. I do not have the lift, so I went to a mechanic. Exactly the symptoms you describe. However, you can also have warped brake rotors. Check suspension first (rear as well). Another possible reason is dented wheel rims. But those would cause vibration without braking. Good luck.
sgtbello
01-16-2006, 03:31 PM
Thank you for the reply.
I checked my suspension as you said and there no dents on my rims. I am leaning toward the other possibilities you had mentioned.
When you say you had to replace your lower front control arms. Are you referring to calipers? Also, what are warped brake rotors?
Thanks so much for your post.
beatruit
08-27-2006, 01:31 PM
your brake rotors need to be replaced
