2004 Venture Headlight Replacement
TRocker
01-12-2006, 05:26 PM
I can't seem to get the driver's side headlight lens off to replace the bulb. The instructions in the owners manual aren't real clear. It looks like you're supposed to take off the side lamp lens assembly to get the headlamp assembly off for access to the bulb.
After taking the three fasteners off, I can't seem to get the side lamp lens off. Is there something I'm missing?
Thanks.
Glen_T
01-12-2006, 06:58 PM
On my Montana, all you have to do is unscrew the thumbscrew that is horizontal, and firmly pull straight forward on the side marker light. There is a clip in back that unsnaps. Then you remove the two (or is it 3?) vertical thumbscrews on the headlamp assembly, and then you sort of lift up and out to get access to the electrical connector and bulb. Hope this helps....Glen
GregA
01-12-2006, 08:38 PM
Glen is right.
If pictures would help, Go Here (http://www.my-chevy-venture.com/headlight-turn-signals.html).
Take Care,
TRocker
01-12-2006, 11:58 PM
Thanks for the suggestions and pictures. I'll give it a shot!
TRocker
