Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > Cressida
Old 01-12-2006, 04:15 PM   #1
genej
genej Normal reputation
Question No power
Okay, here we go. 89 7MGE, no power in lower rpms. Had a BHG, replaced that, didn't make a difference. Acts kinda like it's running WAY too rich, but I can't find any way to adjust fuel mixture. Can't find an idle adjustment screw either. Chiltons shows one on top of the throttle body, but there isn't one on this car.
Check engine light is on and I don't know how to turn it off.
Any help wpuld really be appreciated. Just got the car and love it.
genej is offline   Reply With Quote
Old 01-13-2006, 06:35 AM   #2
lisamac
lisamac Normal reputation
Re: No power
Have your Cat Converter check for Backpressure,anything over 3lbs no good.
Idle air adjustment screw is on the Throttle body.
lisamac is offline   Reply With Quote
Old 01-13-2006, 02:39 PM   #3
genej
Re: Re: No power
I'll check the cat. There are no screws at all on the throttle body. I've looked several times, both when the TB is on and off the car.
Old 01-14-2006, 06:14 AM   #4
lisamac
Re: Re: Re: No power
Every Toyo EFI has a minimun air adjustment its under a plastic cap
Old 01-15-2006, 05:11 PM   #5
genej
Re: No power
That's what I've read and heard, but I don't see a plastic or rubber cap or plug on it. I just mess with the linkage until it's close. I know that's not right, but it's better than idleing at 2K.
By the way, I appreciate your responding. Just wanted to say thanx.
Old 01-15-2006, 05:44 PM   #6
lisamac
Re: No power
On the other side of the Throttle Position Sensor there's a screw,you have to look real close . You can be able to take it down to 750rpm. But before you do that make sure you jump te-1 to e1 at the check connector and check the timing. If correct than go ahead and adjust the Idle.
BTW you're welcome.
Old 01-17-2006, 10:43 PM   #7
flrydr
flrydr Normal reputation
Re: No power
check your o2 sensor it could be giving your computer bad signals.
flrydr is offline   Reply With Quote
Old 01-17-2006, 11:28 PM   #8
genej
Re: No power
Okay, so I broke down and went to a mechanic (!!!) I didn't use a jumper at T1 and E1 when I timed it, and it was way out of time, however he couldn't find an idle adjustment screw either. He got a funny look on his face when I asked him, and when he looked, he couldn't find one either. There's a hole opposite the TPS, and it looks like it might be threaded(kinda hard to tell), I was wondering if the screw might've fallen out? Would it run like that?
Old 01-22-2006, 01:25 AM   #9
lisamac
Re: No power
That's where the screw suppose to be at, when adjusting it you need a feeler gauge its goes a certain K's of an Inch measurement.
Bookmarks
Google
Web AF
