Electric fan for a sr20det swapslociv 06-12-2002, 01:50 PM My buddy is currently doing this swap and i've read in a lot of places that you need to replace the mechincal fan with an electric one. Why is this? Where would you recomend getting one? do i only need one? its an s13 if that makes a difference. J SPEC SilEighty 06-12-2002, 09:51 PM This is directly out of the may 2002 issue of SCC. "The JDM radiator, fan shroud, and hoses should be used if possible. If you have to use the U.S. radiator, the radiator outlets will be in the wrong place. A few 90-degree radiator hoses and a length of aluminum pipe make an easy crossover pipe. With a U.S. radiator, you'll need to switch to electric fans, since the stock fan shroud won't fit. If, like us, you have the JDM parts and you plan to keep air conditioning, you'll have to trim the fan shroud to clear the A/C reciever/drier." Automotive Network, Inc., Copyright ©2012
