Re: 97 Astro Fuel Pump
I replaced the pump on my '97.
The hardest part I found was the "quick connects" at the tank, about a half hour each due to corrosion. (3 of them)
I needed to raise 1 side of the van, by using 2x6 wood, to get it high enough to get the tank from under the van. (no running boards) I blocked the front and rear of the tank on many wooden blocks to 'see-saw" the tank to the ground. Fuel is about 7 lbs/ gallon, and it sloshes around.
The fuel fill line has another rubber pipe inside the 1 you see, and is also cause for a few words.
I don't remember how I got the pump out, I didn't have a problem with the snap ring, I probably tapped it out with a brass drift.
A few people have said they broke the welded nuts out of the frame. I soaked mine the day before I worked on it. And you can save some time if you remember which strap is front and which is back.....
Pay attention to the way it comes out, re: fuel level sender. At least it doesn't matter if you bought the assembly.
Also, MAKE SURE the electrical connector is in mint shape, no signs of melting. My assmebly came with an electrical grease for that connection. There's about 10 amps flowing thru there while the engine runs, and the connector may overheat.
Not too bad a job. I think it took me a half day. (but spray the tank bolts a day before)
