'92 Sl2 A/ccammiephoto 06-12-2002, 11:04 AM I have a "92 SL2 and the A/C isn't cold. It blows and the compressor seems to work. Do I just need freon? How can I check? Thanks I'm A/C Stupid!!! V/R cammiephoto memoore 07-30-2002, 06:57 PM I had much the same problem with my 94 SL2. I found out that the radiator fan was not working - check to see if it kicks on when the A/C is on. These cars don't overheat unless you're stuck in heavy traffic without the radiator fan. I got a replacement motor from Autozone for $21 and it took about an hour to replace. Hope this helps. UncleMeat777 07-30-2002, 07:41 PM If that doesn't work I believe some autopart stores will sell coolant refill kits. Otherwise it could be up to $100 through the dealer. bman37 01-01-2004, 04:21 AM My guess is r134 system needs charged i woud recomend a ac flush and new oil by a professional Automotive Network, Inc., Copyright ©2012
